Timing hard to set with thicker head gasket, please help.
Old Jun 13, 2006 | 11:17 PM
Xgen's Avatar
Default Timing hard to set with thicker head gasket, please help.
I also posted this in the FI section, I really need to figure this out guys.
This is my problem, I asked here since I know alot of you guys use thicker head gaskets. I have a Cometic .45 HG
when I set my cam timing to 16 BTDC I have everything set perfect, when I go to put my timing belt back on with the tensioner all the way loose, the belt wont allign with the teeth on the cams, and its a pain in the *** to put on because its so tight, would a head gasket of such make that much of a difference?
Could this also be causing the timing belt to be 1/2 a tooth off when trying to slide it on the cam gears when everything is set in its proper place (cams at TDC and pulley at 16BTDC)
I need help with this guys.
Old Jun 14, 2006 | 06:20 AM
EG civic's Avatar
Default Re: Timing hard to set with thicker head gasket, please help. (Xgen)
The pulley should be at TDC not 16BTC. The single marking after the 3 timing marks.
Old Jun 14, 2006 | 12:58 PM
Xgen's Avatar
Default Re: Timing hard to set with thicker head gasket, please help. (EG civic)
I did it this way and it runs like ****, timing is still off.
Old Jun 14, 2006 | 01:40 PM
sik96teg's Avatar
try turning your cams a bit counter clockwise to fit the belt on our get adjustable cam gears if its way off.
boomersz
Apr 5, 2007 11:14 PM
boomersz
Apr 5, 2007 09:33 PM
.RJ
May 8, 2003 10:45 AM
TurboedGSR
Aug 24, 2002 06:10 PM
