B16 cometic head gasket, now cam timing is hard to set properly. HELP.
This is my problem, I asked here since I know alot of you guys use thicker head gaskets. I have a Cometic .45 HG
when I set my cam timing to 16 BTDC I have everything set perfect, when I go to put my timing belt back on with the tensioner all the way loose, the belt wont allign with the teeth on the cams, and its a pain in the *** to put on because its so tight, would a head gasket of such make that much of a difference?
Could this also be causing the timing belt to be 1/2 a tooth off when trying to slide it on the cam gears when everything is set in its proper place (cams at TDC and pulley at 16BTDC)
I need help with this guys.
shm91
Oct 25, 2013 08:44 AM
-singlecamkillr
Apr 20, 2005 11:20 AM
