Which 2 guages?
Old Apr 16, 2002 | 10:21 AM
B2FiNiTY's Avatar
Default Which 2 guages?
If you had to pick only 2 aftermarket guages in the car, which ones?
I.E.- oil temp, a/f, oil pressure, voltmeter etc
Old Apr 16, 2002 | 10:27 AM
D's Avatar
D
Default Re: Which 2 guages? (B2FiNiTY)
AF and voltmeter.
see sig.
D
Old Apr 16, 2002 | 10:28 AM
B2FiNiTY's Avatar
Default Re: Which 2 guages? (D)
Why voltmeter?
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Why voltmeter?
Cause he's selling one.
Old Apr 16, 2002 | 10:33 AM
J_Edwards's Avatar
Default Re: Which 2 guages? (FL n NC rock j00)
I would say AF and oil pressure....although I would like to have a water temp gauge also....so I guess I wouldn't be happy with only two.
Old Apr 16, 2002 | 10:44 AM
Rob :190:'s Avatar
Default Re: Which 2 guages? (mr. clockwork)
i'd say oil temp and pressure, but ideally i'd have oil temp, water temp, and oil pressure.
Rory Breaker's Avatar
Boost and A/F
Old Apr 16, 2002 | 10:45 AM
ITRinEJ1's Avatar
Default Re: Which 2 guages? (Brian Spilner)
Old Apr 16, 2002 | 10:46 AM
GokuSSJ4's Avatar
oil pressure , A/F
Old Apr 16, 2002 | 10:49 AM
onyx00's Avatar
Default Re: Which 2 guages? (Spoon1)
How does the A/F gauge install, like what is it hooked in to?
Old Apr 16, 2002 | 10:56 AM
EJK's Avatar
EJK
New User
Default Re: Which 2 guages? (onyx00)
just the 02 signal wire, ground and 12+ ignition.
Old Apr 16, 2002 | 10:58 AM
B2FiNiTY's Avatar
Default Re: Which 2 guages? (SLPMDE01)
I'm leaning towards Oil temp and A/f... is the A/f that necessary? The oil pressure guage might be more important.
Old Apr 16, 2002 | 11:06 AM
onyx00's Avatar
I would think A/F wouldn't be that big of a deal; I mean once you tune the car the A/F should stay reasonably constant. Maybe changing weather would throw it off a little, but the gauge is not totally accurate to begin with.
I would say start with a good oil temp gauge. Spend your money on that, and get a good one that gives accurate readings.
Old Apr 16, 2002 | 11:09 AM
B2FiNiTY's Avatar
Who makes a good one? I'm leaning towards the Apexi Oil temp but it's pretty expensive. How's the autometer?
Old Apr 16, 2002 | 11:10 AM
yellow blur's Avatar
Boost and EGT
Defi would be my choice.
Old Apr 16, 2002 | 11:11 AM
Austin's Avatar
There are 3 of them that I would use:
Oil Temp
Oil Pressure
Fuel Pressure
I feel that these are a must on a modified car...especially one that will, at times, see track use.
Austin
Old Apr 16, 2002 | 11:17 AM
B2FiNiTY's Avatar
Default Re: Which 2 guages? (Austin)
Those Defi guages look very nice, anyone on the board can get them?
Old Apr 16, 2002 | 11:19 AM
Austin's Avatar
Mike @ IPS should have an account with them...I had a conversation with him about them ~2 months ago.
Austin
Old Apr 16, 2002 | 11:20 AM
norice's Avatar
You could also use SPA dual gauges:
http://www.syclone.freeserve.co.uk/spagauges.htm
I am thinking of doing an oil temperature/pressure and water temperature/fuel pressure combo in the future.
Old Apr 16, 2002 | 11:24 AM
Austin's Avatar
Default Re: Which 2 guages? (norice)
Looks cool...might just be easier to get one of the dual Omori, or Defi guages.
Old Apr 16, 2002 | 11:27 AM
GokuSSJ4's Avatar
B2FiNiTY
have you pick a brand in particular??
Old Apr 16, 2002 | 12:39 PM
B2FiNiTY's Avatar
So far...Defi, Apexi, and autometer in that order.
Old Apr 16, 2002 | 02:00 PM
tjtruong's Avatar
New User
defi ..
if you want we can order them together..
tj
Old Apr 16, 2002 | 02:07 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
NA: EGT and Fuel Pressure
FI: Boost and EGT
Old Apr 16, 2002 | 02:12 PM
B2FiNiTY's Avatar
Default Re: Which 2 guages? (newt2)
What's EGT?
Upon closer inspection I think I have a winner. It seems like the defi guages will fit the autometer gauge pod.
