98 ex v-6 air conditioning
hey guys, for some odd reason my air conditioning would only work if i put it on full blast (not auto). if i move it into another position, there would be no air whatsoever coming out. i dont know what to do, can someone help?
I would hope not becuase that thing is expensive.
The climate control unit has a self-diagnosis function.
Running the Self-diagnosis Function
Turn the ignition switch ON (II).
Set the temperature control dial on Max Cool, then slowly to Max Hot.
After 1 minute, press the AUTO button and then the OFF button. Continue to hold both buttons down. If there is any abnormality in the system when both buttons are pressed, the temperature indicator will light up the segment (A to N) corresponding to the error. The temperature indicator will then alternate every second between displaying ''88'' (all segments lit) and the error segment. If there is no abnormality, the segments will not light up.
ejfromwestbay
Dec 26, 2012 09:23 PM
andrewfreestuff
Aug 24, 2009 09:06 PM
