B16A2 w/ PCT pistons: To flycut valve relief or not?
Old Jun 13, 2006 | 07:38 PM
Ninja Mike's Avatar
Default B16A2 w/ PCT pistons: To flycut valve relief or not?
Do you have to modify the dome of the piston?
Thanks,
-Mike
Modified by SleepEMike at 6:02 AM 9/4/2006
Old Jun 14, 2006 | 12:18 AM
Serdar's Avatar
Default Re: B16A2 w/ PCT pistons: To flycut valve relief or not? (SleepEMike)
bump, helpp!
Old Jun 14, 2006 | 05:49 AM
UncleD's Avatar
Default Re: B16A2 w/ PCT pistons: To flycut valve relief or not? (Serdar)
I think you'll be ok, but to be sure I might pm DonF or another engine builder here on H-T. You might just hafta clay it.
Old Jun 14, 2006 | 08:05 AM
the DOT's Avatar
i would just clay check it,its not that hard to do just a lil time consuming
Old Jun 14, 2006 | 10:09 AM
DonF's Avatar
Default Re: (the DOT)
I have not checked the PCT piston, it looks OK, but you need to check it. PM me the "deck" height.
Old Jun 14, 2006 | 02:13 PM
dohcMONSTER's Avatar
Default Re: (DonF)
you should be fine i'm running PCT's with a milled p72 head and i have no problems
Old Jun 14, 2006 | 02:22 PM
the DOT's Avatar
Default Re: (dohcMONSTER)
are you running oversized valves?
Old Jun 14, 2006 | 05:50 PM
Combustion Contraption's Avatar
It says he is right in the first post.
Old Jun 14, 2006 | 06:19 PM
Ninja Mike's Avatar
The stock new OEM Honda head gasket of which I'll be using... do they measure in at .026?
Modified by SleepEMike at 6:03 AM 9/4/2006
Old Jun 15, 2006 | 12:29 AM
Serdar's Avatar
Default Re: (SleepEMike)
Me & Mike Will try and check the deck height but I dont have anything very accurate to measure?? I think it was resurfaced tho.
Modified by Serdar at 4:41 AM 6/15/2006
Old Jun 15, 2006 | 04:13 AM
the DOT's Avatar
Default Re: (Combustion Contraption)
you read well my reply was to dohcmonster not sleepemike who i know has oversized valves
Old Jul 16, 2006 | 01:40 PM
Ninja Mike's Avatar
Well, the cumbustion chamber checked out clear across...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">I have not checked the PCT piston, it looks OK, but you need to check it. PM me the "deck" height.</TD></TR></TABLE>
PM sent
Modified by SleepEMike at 3:54 AM 7/21/2006
ohsnapzafingcu
Aug 7, 2010 07:40 AM
gsrcoupee
May 9, 2010 11:01 AM
DougieFreshZero
Acura TSX
Jan 12, 2009 05:29 PM
lyckaon
Nov 20, 2005 11:05 PM
SprayinCX
Aug 12, 2003 03:27 AM
