Built Turbo Motor w/o Turbo....going to hit the dyno for the hell of it.
Old Jun 13, 2006 | 12:54 PM
96 GSR-T's Avatar
Default Built Turbo Motor w/o Turbo....going to hit the dyno for the hell of it.
Just out of curiosity, what HP do you all think I will hit with this setup Non-Turbo as I have to wait a little while more to throw some boost in it, I was hoping for somewhere around 160whp, will be hitting the dyno soon for 3 pulls..... Car feels very strong for being low Comp and pulled 190-200 on a Comp. Test with 350 miles on it.
B18C1 New displacement 1820cc / 9.1 to 1 Comp. Ratio
81mm Eagle Sleeves Bored .5mm Oversize
Weisco 81.5mm Pistons
Crower Steel Billet Rods
Toda Oil Pump
ACL Bearings
Micropolished Crank
Moroso 5.5 Quart Steel Oil Pan
Port & Polish
Exhaust Guides Shaved
5 Angle Valve Job
Ferrea .5mm Oversize Super Alloy Valves
Ferrea Dual High Pressure Turbo Valve Springs
Ferrea Seat Locators/Retainers/Locks/Guides/Valve Seals etc.
Stock GSR Cams
AEM Cam Gears
MSD 6A, Cap, Blaster Coil, 8.5mm Wires
Victor X Manny
BBK 70mm TB
3" Short Ram w/ 3" HKS Megaflow
AEM Fuel Rail, Press Reg
Stock Injectors
Walbro 255
Stock Header/Exhaust w/ no axle back
Hondata S300
Any comments welcome
Old Jun 13, 2006 | 04:50 PM
96 GSR-T's Avatar
Well guess I should of read the guidlines for this forum.... specifially #4, but I was just curious, 40 some views and not 1 reply....boo
Old Jun 13, 2006 | 05:30 PM
lohatch's Avatar
Default Re: (96 GSR-T)
150ish whp +/- 10
Old Jun 13, 2006 | 07:41 PM
96 GSR-T's Avatar
Default Re: (lohatch)
Thank you sir.... what are stock GSR's?, in that range correct. I am running a stock computer right now but my P28 with my S300 comes tomorrow so I am gonna tune it and hit the dyno. The car is a real dog under 6k (prob the int. manny and 70mm TB) but around 7k it really pulls hard for a low comp car.
catolarfo
Oct 20, 2009 05:50 AM
1FSTNDN
72
Sep 8, 2007 08:40 AM
1FSTNDN
Feb 3, 2007 10:48 PM
Jan 24, 2003 04:58 AM
