exhaust note suddenly changed
hey all, i was drivin my car the other day, pulled in to my driveway and then noticed my exhaust note suddenly changed. my car kind of sounds like a wrx now. iono. its completely stock d16y7 00 civic lx. Does anyone know what this could be?
its my bday today too! i'm 21
ty for your help
ty for your help
you sure you got gas in your car? i seen it happen before, my friend thought the same thing and i told him he was low on gas and he thought i was crazy. but he put in 2 gallons and it went away
how about you make sure its not just an exhaust leak instead of starting to tear stuff down and do compression checks, etc.
go drive the car. if it feels normal just louder its probably a leak near the head/manifold
If the car is running, power wise the same, I will put $$$$ that you have an exhaust leak. Sounds like rusted exhaust piping finally gave out.
hrm i havn't really pushed it since the sound has changed but i havn't noticed much of a difference. i'll take a look under the car tomorrow. Should i notice a big difference in power on 3 cylinders? or is this somethin i have to feel for.
thanks for everyones inmput
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">Your car would be hardly running if you are on 3 cylinders. Wait, you have a SOHC, won't notice much of a difference.
Why not go and look under your car right now?</TD></TR></TABLE>
its definately not hardly running. so i guess it can't be 3 cyli then? i'mma just look under to eliminate the exhaust thing, i'll let you all kno thanks all!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Does the car feel like it vibrates more? Touch the hood or someting, does it feel ike it shakes more than usual?</TD></TR></TABLE>
you mean does the idle drop so low that it shutters about to stall? nah not really
might vibrate a lil more then usual though.
i noticved when i got home from the bar tonite ( i wasn't drivin) i started my car up and upon startup when you hit the gas it deffinately vibrates more then usual. seems to go away after runnin for a min or two. what hte deal w/ that
Have you found your exhaust leak yet? If you car is idling rough you could have a cracked/broken motor mount, as well. I'm still curious to see what the cause of this is, keep us posted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0nfry »</TD></TR><TR><TD CLASS="quote">is it safe to turn my car on, and unplug one plug wire at a time, so i know which cylinder is down?</TD></TR></TABLE>
Yep its perfectly safe. and if you can put it up on ramps or a lift and listen for anything that sounds out of place. *ie exhaust leak.
After whats been said if you don't notice that the car is running hard/differently its an exhaust leak. running on three cylinders is quite noticeable as you will see.
