JDM H22a Block And Type S Piston Quick Question (Searched)
Old Jun 13, 2006 | 11:13 AM
Techna600f4i's Avatar
Default JDM H22a Block And Type S Piston Quick Question (Searched)
I cam across an H22a JDM Block, Can i add type S Pistons without doing any other work? Also Will Crower Stage II Cams Be able to run with this setup. Thanks
Old Jun 13, 2006 | 11:21 AM
98vtec's Avatar
moderator emeritus
Default Re: JDM H22a Block And Type S Piston Quick Question (Techna600f4i)
as long as the crosshatches on the cylinder walls are ok from the stock hone, then all you would need to do is put them in. BUt considering the fact that the block is not in the car and a hone really isnt expensive, i would get a fresh hone just to reassure myself.
Crower stage II isnt really THAT aggressive of a cam. With 11:1 compression you could go with a more aggressive cam and not be sacrificing anything downlow-midrange
Old Jun 13, 2006 | 11:25 AM
Default Re: JDM H22a Block And Type S Piston Quick Question (98vtec)
Thank you much!
Old Jun 13, 2006 | 11:27 AM
98vtec's Avatar
moderator emeritus
just MAKE SURE that whoever you have hone your block, make sure they know what to do with FRM sleeves. It takes a particular stone to hone and if you use the wrong one you are s.o.l.
Old Jun 13, 2006 | 11:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">just MAKE SURE that whoever you have hone your block, make sure they know what to do with FRM sleeves. It takes a particular stone to hone and if you use the wrong one you are s.o.l.</TD></TR></TABLE>
Yeppers,
Sportcar motion, deal with hondas and H series. They know about FRM
Thanks again.
Old Jun 13, 2006 | 11:39 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techna600f4i &raquo;</TD></TR><TR><TD CLASS="quote">Yeppers,
Thanks again.</TD></TR></TABLE>
well there you go
Old Jun 13, 2006 | 12:32 PM
Buffalo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">as long as the crosshatches on the cylinder walls are ok from the stock hone, then all you would need to do is put them in. BUt considering the fact that the block is not in the car and a hone really isnt expensive, i would get a fresh hone just to reassure myself.
Crower stage II isnt really THAT aggressive of a cam. With 11:1 compression you could go with a more aggressive cam and not be sacrificing anything downlow-midrange</TD></TR></TABLE>
cos i was having the same question... if the cylinder walls are just fine the pistons are just "plug-n-play" situation right? thats the same with any stock size bore aftermarket piston (any compression)?
A Blue Lude's Avatar
If it's an older H22 you'll need to have your rods rebushed for floating pins, but that's about it.
Old Jun 13, 2006 | 01:15 PM
Default Re: JDM H22a Block And Type S Piston Quick Question (A Blue Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A Blue Lude &raquo;</TD></TR><TR><TD CLASS="quote">If it's an older H22 you'll need to have your rods rebushed for floating pins, but that's about it.</TD></TR></TABLE>
If aftermarket rods are used, IE... Eagle H Beam would that be ok.?
Old Jun 13, 2006 | 01:27 PM
oranginal's Avatar
the crower stage II cams require the upgraded valve train to rev it higher to get the max power and potential. if you have a type s head i know the valve train is a little stronger but the rev it higher u would need the upgraded valve train, if not you better make sure not to miss a shift and rev too high.
hope this helps.
Old Jun 13, 2006 | 02:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techna600f4i &raquo;</TD></TR><TR><TD CLASS="quote">If aftermarket rods are used, IE... Eagle H Beam would that be ok.?</TD></TR></TABLE>
Eagle makes two. You want this one:
http://www.eaglerod.com/produc....html
p/n: CRS5630J3D
Old Jun 13, 2006 | 09:03 PM
Thanks for everyones help, much apriciated
Old Jun 14, 2006 | 09:55 AM
v4lu3s's Avatar
RTFM
when you go for the hone, print off the honda specs for the honing process on teh FRM. I took the sheet into 3 shops and they all said the stone was not an isuse since its used often, but it ws the very low rpm and limited number of turns in the hole tht were an issue, the RPM especially.
civicf20bitb
Dec 16, 2008 07:17 AM
mikeaitken
Apr 15, 2007 06:20 AM
11seclude
Oct 30, 2005 10:05 AM
Showoff
Oct 16, 2003 01:58 PM
Showoff
Oct 16, 2003 07:05 AM
