gauge question
Old Jun 13, 2006 | 10:06 AM
DelSolMarine's Avatar
Default gauge question
i got a b18c swap put in a del sol si... well im about to chip my ecu to take off the governor and i needa change my tach casue the redline says 7200 instead of 8200 well anyway and my speedo says 125 so leading to my question..
http://www.autometer.com/cat_g...zid=6
i found those guages... question is is 3 3/8's the correct size? will those fit right in?
NJcoupe's Avatar
Default Re: gauge question (DelSolMarine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine &raquo;</TD></TR><TR><TD CLASS="quote">i got a b18c swap put in a del sol si... well im about to chip my ecu to take off the governor and i needa change my tach casue the redline says 7200 instead of 8200 well anyway and my speedo says 125 so leading to my question..
i found those guages... question is is 3 3/8's the correct size? will those fit right in?</TD></TR></TABLE>
They will not fit in directly without modification. Best bet, is to ignore the tach, and get a shiftlight with the light set at 7200.
Old Jun 13, 2006 | 10:49 AM
SovXietday's Avatar
Default Re: gauge question (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">They will not fit in directly without modification. Best bet, is to ignore the tach, and get a shiftlight with the light set at 7200. </TD></TR></TABLE>
Heh, shift point in a GSR at 7200, that's kinda funny.
Do what he said, but set it at 8100 (give yourself some time to react)
Delsol_Drew
Oct 17, 2014 04:41 PM
lYellowDragonl
Oct 18, 2004 06:25 PM
BrianDelSol
Jul 27, 2004 03:21 PM
binkster
Jan 30, 2003 04:09 PM
