Brakes wobble under heavy braking. Warped rotors?
Old Apr 16, 2002 | 08:56 AM
Rob :190:'s Avatar
Default Brakes wobble under heavy braking. Warped rotors?
problem started a little while ago, under moderate to heavy braking, i feel a wobble in the steering wheel, tiny movements. I dont really have to correct or anything, but its noticable. BTW, i had this problem before i removed the PS, so that doesnt have anything to do with it. Also, before someone calls me a moron, its not the ABS. I know what that feels like, and this is not it. Warped rotors ya'll think?
ps- any chance of getting warped rotors replaced under warranty (if thats what it is)?
Old Apr 16, 2002 | 09:01 AM
AssPenny's Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (Brian Spilner)
Pull out the dial indicator and check it out. Most likely if you've been running after market pads or realy pushed the stock pads hard on a corse, then yes its warped rotors.
And no they won't cover it under warrenty, its a wear item. Unless you got like 2,000 miles on it.
Old Apr 16, 2002 | 09:03 AM
JPP's Avatar
JPP
Good chance it is a warped rotor. If you are lucky it is not to bad and they can machine it without going under limit specs. I had it done and it was good for an other summer. But they warped again and now I have to change rotors ( this week hopefully).
If I remember correctly it was not under warrenty. Rotors are considered normal maintenance items.
Old Apr 16, 2002 | 09:05 AM
typer_801's Avatar
It's probably you're rotors. One thing you might check is the torque on all of your lugs. Sometimes uneven tighening can cause this symptom you mentioned and just correcting the torque to 80-85 ft/lbs ea. solves the problem. Otherwise, you'll probably need new rotors. Colletti Motorsports has Brembo blanks for around $40 ea for the ITR if you need them.
Old Apr 16, 2002 | 09:08 AM
AssPenny's Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (typer_801)
I've got an order waiting for colletti right now. Its 190 shipped for all 4 rotors, unfortiently, they don't have the rears in yet. They are going to mail me as soon as they come in.
Old Apr 16, 2002 | 09:10 AM
yoshi234's Avatar
I shoot brides
not sure what kinda of pads you're running, but it can also be uneven pad deposits on the rotor.
yshi - whose had this problem
Old Apr 16, 2002 | 09:15 AM
Rob :190:'s Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (yoshi234)
stock pads.
i think i'm gonna get everything changed (rotors, pads, fluid etc) this summer (just 3 weeks away ) in preparation for popping my track cherry at VIR with the bmw folks.
Ok guys, new question. This will be my first track event, should i just get OEM brake stuff, or upgrade?
[Modified by Brian Spilner, 1:21 PM 4/16/2002]
Old Apr 16, 2002 | 09:34 AM
Willard's Avatar
Autozone rotors 95 Legend (~$25.00 each)
ATE super blue
Panther pads on the front stock on the rears
BWM club will not know what hit it.
Will
Old Apr 16, 2002 | 09:37 AM
AssPenny's Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (Willard)
I dunno about autozone rotors... thouse things crack/warp left and right.
[Modified by AssPenny, 1:38 PM 4/16/2002]
Old Apr 16, 2002 | 09:43 AM
Willard's Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (AssPenny)
not this again...
Will
-who likes cheap wear items.
Old Apr 16, 2002 | 09:46 AM
Rob :190:'s Avatar
stainless lines? or ?
Old Apr 16, 2002 | 09:47 AM
Willard's Avatar
unless the car is very old.
save that mod for later... there is better stuff to work on now.
Will
Old Apr 16, 2002 | 09:49 AM
AssPenny's Avatar
Damn Will, you are just tearing me down.
Craig - Who has SS lines and is getting Brembo Blanks
[Modified by AssPenny, 1:49 PM 4/16/2002]
Old Apr 16, 2002 | 09:50 AM
Willard's Avatar
not tearing you down... just suggesting cheap ideas...
Will
-who wishes he had azzdollar's cash flow..
Old Apr 16, 2002 | 09:52 AM
H-PIMP's Avatar
Sounds like warped rotors to me.
Old Apr 16, 2002 | 09:57 AM
Rob :190:'s Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (H-PIMP)
thanks for all the help guys. After the damn post ***** orgy that was asspenny's campaign for Mod status, i'm surprised they still let me on here.
Brake check list for #1035:
Pads-panther (+ I guess)
lines- OEM (for now)
rotors- Autozone or OEM (depends on flow)
MC brace- if them bums would get around to building that ****
again thanks for the help
Old Apr 16, 2002 | 09:59 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
yoshi, that's what a warped rotor is really
Willard's Avatar
-pads = any good aftermarket set will be better than stock.
-nice
-OEM, one rotor = 3 Autozone rotors
Will
-who is p00r
Old Apr 16, 2002 | 10:01 AM
Willard's Avatar
Default Re: Brakes wobble under heavy braking. Warped rotors? (FL n NC rock j00)
even if the dial indicator shows run out?
Will
-who is PW'ing
MUGEN_EG95
Honda Civic (2006 - 2015)
13
Apr 20, 2008 10:15 PM
mechengine
Apr 3, 2004 10:48 PM
nikolai.
Nov 23, 2003 05:28 PM
1337 Si
Nov 25, 2002 05:51 AM
TsunamiZC
Oct 7, 2002 01:40 PM
