Sputering rev/ High idle
Old Jun 12, 2006 | 09:52 PM
Civic Hybrid's Avatar
Default Sputering rev/ High idle
I have seriously had enough of this crap. I have a b16a. My idle has gotten worse over the past weeks and now it has started tp speraticaly rev plus the idle sits at like 2000/2300 rpms. I am so frustrated and don't no wat to do. I cleaned my IAVC, my throttle cable is loose, and I took off my intake and my TB remains closed. Iv'e heard I could have a vaccuum leak but wat is the easiest way to see if I do. I have the correct ECU. I also heard it could be the FITV.... do i even have one??? How to I correct the FITV if I have one. PLEASE help..... info is greatly appreaciated.
Old Jun 12, 2006 | 09:53 PM
FalkenSiR's Avatar
Default Re: Sputering rev/ High idle (Civic Hybrid)
what year car do you have? What year engine do you have? what ecu? and most importantly, did you scrape off the eacv and put some sealant before you installed it on the car?
Old Jun 12, 2006 | 10:04 PM
Default Re: Sputering rev/ High idle (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">what year car do you have? What year engine do you have? what ecu? and most importantly, did you scrape off the eacv and put some sealant before you installed it on the car?</TD></TR></TABLE>
I have a 2000 civic hatch. And a 92-95 b16a swap. The ecu is a p30 obd1. not to sure wat u mean my eacv...i didn't do the swap myself...so if u can explain?
Old Jun 12, 2006 | 10:28 PM
spikiexmikie's Avatar
i think u might have a vacuum leak. check all your hoses. try spraying some starting fluid or something around and see if your idle changes.
Old Jun 12, 2006 | 11:19 PM
Default Re: Sputering rev/ High idle (spikiexmikie)
sounds dumb but wats starting fluid??
Old Jun 13, 2006 | 09:09 AM
BUMP
NA_B_FTW
Feb 11, 2009 12:06 PM
snouka
11
Mar 25, 2005 06:01 AM
old_school_dohcvtec
Feb 4, 2005 11:06 PM
joedr
Sep 10, 2002 05:07 AM
SjCiViCHB
Dec 1, 2001 01:45 AM
