rear shim kit question
Old Jun 12, 2006 | 08:20 PM
Tealeg88's Avatar
Default rear shim kit question
I have a 98 hatch and i have -2.4 degrees on the left and -2.9 on the right. I just bought that rear shim kit that is sold by omini power. should i use two washers on the left and three on the right? The kit is rated to adjust your camber up to 1.5 degrees of positive camber so i figuired each washer would give me a positive half a degree. Is my assumption right? I am trying to for around -1.5 in the rear.
Old Jun 13, 2006 | 07:31 AM
Tealeg88's Avatar
Default Re: rear shim kit question (Tealeg88)
bump
Old Jun 13, 2006 | 07:37 AM
EGin6's Avatar
use three on each side
Old Jun 13, 2006 | 09:36 AM
Tealeg88's Avatar
Default Re: (EGin6)
woudn't it make sense to put two washers on the left and three on the right becasue of the differences in degrees?
Old Jun 13, 2006 | 06:43 PM
Tealeg88's Avatar
Default Re: (Tealeg88)
Old Jun 13, 2006 | 07:18 PM
mathieucivic's Avatar
put the same quantity on both side dude!
on a batch of washer, most of the time you found different thinkness.
Old Jun 13, 2006 | 07:20 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
ya put 3. The left side is less negative now, but think about when the driver sits in the car
watacivic
23
Dec 5, 2008 06:12 PM
EGLUVN
Apr 26, 2008 12:06 AM
funkdocivic
15
Jul 27, 2007 12:23 PM
Deathwish
Suspension & Brakes
Jul 10, 2005 08:40 PM
Mugen Hamster
May 5, 2003 11:51 AM
