D16Z6 into a 96 EK (obd2a)
Old Jun 12, 2006 | 07:32 PM
youngwon22's Avatar
Default D16Z6 into a 96 EK (obd2a)
I have a 96 ek shell, and a d16z6 motor with all stock parts ( no obd2 parts )
I also have a obd2a wiring harness to work with, and don't know what other parts i will need nor what I will have to do to make this car running.
I was told that a jumper harness will work but is that possible with obd1 injectors/alternator/dizzy/starter/etc?
Any help would be appreciated
Thanks in advance
Old Jun 13, 2006 | 12:53 PM
youngwon22's Avatar
searching & FAQ didn't get me an answer... anyone?
Old Jun 13, 2006 | 01:32 PM
Cvic90's Avatar
Default Re: D16Z6 into a 96 EK (youngwon22)
It can but it's alot of work. U need to get a OBD2 dizzy and put the guts from it in the Z6 dizzy shell. the alternator will work if you have an OBD1 plug to wire into place of the other ( they are usually the same color wires). Same with the injectors or you could get some D16Y8 injectors and not cut the plugs. those are the biggest changes. I know caz I'm running a supercharged Z6 in my 96 EK. I just swapped the guts of the dizzy's and got OBD2 injectors and alternator. All else is stock ek mounts.
miamihonda
Jan 22, 2013 05:07 PM
jlbarrios
14
Dec 27, 2011 04:55 PM
EGhatch33
Jan 12, 2007 09:54 AM
kevbo82
Jul 21, 2005 03:16 PM
