Sputtering when cold
Old Jun 12, 2006 | 07:08 PM
EG2Driver's Avatar
Default Sputtering when cold
My B16A3, when cold, has erratic idle and sometimes sputters because one of the cylinders is not firing, but only when cold. It also occurs at random (not only between 2000rpm and 3000 rpm)
Parts i looked at/cleaned
1-Distributor cap and rotors--->Used a dremel to resurface the contact surfaces
2-Wires are all the way in (all 4)
3-Plugs are good---------------->cleaned up some carbon buildup
4-Will clean out the IACV tomorrow (10pm right now)
Anything else i could do before i start replacing parts? Thank you for the help!
cityjack
Jan 1, 2015 09:59 PM
N4m
Aug 8, 2012 12:57 PM
JJexpress
May 19, 2009 03:16 PM
EG2Driver
Jun 12, 2006 07:10 PM
