Popping noise while steering
Old Jun 12, 2006 | 04:13 PM
Mr. Brightside's Avatar
Default Popping noise while steering
Lately I have been noticing my car making a popping noise while steering . It only happens when I am below 10 mph. It sounds like the popping is coming from the front suspension. I was wondering if any of you had an idea what it could be. I checked the power steering fluid, and it is full. I have a 2006 type s, I don't drive it hard or have any modifications. Thanks.
Old Jun 12, 2006 | 05:20 PM
whiteDCfiver's Avatar
Default Re: Popping noise while steering (Mr. Brightside)
certain 05's and 06's do it. Theres a propper term for it, i forget, but mechanically i dont think theres anything wrong with your car.
Old Jun 12, 2006 | 06:32 PM
Default Re: Popping noise while steering (whiteDCfiver)
I haven't noticed any decrease in performance, it just bothers me that it is making noise. I am going to talk to a mechanic friend of mine, and maybe talk to the dealer.
Old Jun 13, 2006 | 06:18 AM
The Tech-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteDCfiver &raquo;</TD></TR><TR><TD CLASS="quote">certain 05's and 06's do it. Theres a propper term for it, i forget, but mechanically i dont think theres anything wrong with your car.</TD></TR></TABLE>
Actually there is a problem with his car if his suspension is popping, you're telling me that it's normal and his suspension should be popping? lol oh boy.
To the OP bring your car to your dealer and have them fix that problem, don't allow them to tell you that it's normal for ANY vehicles suspension to make popping noises.
Old Jun 13, 2006 | 06:41 AM
Default Re: Popping noise while steering (The Tech-1)
Thanks for the advice tech, I'm going to take it in as soon as possible.
Old Jun 13, 2006 | 07:01 AM
The Tech-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Brightside &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advice tech, I'm going to take it in as soon as possible. </TD></TR></TABLE>
Im not going to say I know why it's popping but most likely NOT because of struts/shocks. Most likely not enough clearance in between the perch so they'll have to adjust the clearnace. Let us know what they say. They should have a service bulletin about it, they should be well aware of the problem.
Old Jun 13, 2006 | 11:36 AM
Haha, well the guy who helped me out said that it was normal to be hearing these noises, I think it was because the popping isn't that loud. He said that if it got any worse to bring it back.
Old Jun 13, 2006 | 11:41 AM
The Tech-1's Avatar
Suspension popping noises are not normal! You have a brand new 2006!! Tell those lazy fkks to fix it!
Old Jun 13, 2006 | 01:53 PM
E-Money's Avatar
i have a the same popping noise coming from my '02 Si.... i dont know if its axle related though
Old Jun 13, 2006 | 03:47 PM
Default Re: Popping noise while steering (E-Money)
I'm pretty sure that my sound is coming from the suspension, if anything happens the dealer is going to hear about it. But, I was reading some where that suspension needs to settle then the bolts where the suspension connects to the body of car need to be tightened. If anyone has info on this that would be great, I'm going to check it out on my car and see if that fixes things.
Old Jun 13, 2006 | 05:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tech-1 &raquo;</TD></TR><TR><TD CLASS="quote">
I didnt say it should be, but its not abnormal. Search clubrsx.
Old Jun 13, 2006 | 05:50 PM
JDM yo!
Guest
Posts: n/a
i had the same problem with my 04, then i realized it was a spare tire tool rolling around in the spare tire pit.... check that lol
Old Jun 13, 2006 | 06:22 PM
96 SOHC VTEC's Avatar
There are lots of people having this problem on the 05-06's. There is a service bulletin out there for it, but I don't remember where. I had this problem with my Type-S. I took it to the dealership along with the complaint and they had heard of the problem before. They added silencer tubes or something of that nature and it solved the problem. It hasn't done it since and the car now has 25,000 miles.
Search for a service bulletin or a thread like this on ClubRSX.com. Your sure to find your answer there.
Old Jun 13, 2006 | 08:07 PM
Default Re: Popping noise while steering (96 SOHC VTEC)
Apparently this has happened to a lot of people on clubrsx. The fix seems to be silencer tubes from the mdx. I am going to call acura to see what the deal is.
Old Jun 14, 2006 | 12:34 PM
phthalo's Avatar
GDD4LIFE
are your lugnuts tight?
Old Jun 14, 2006 | 12:40 PM
Default Re: Popping noise while steering (phthalo)
Yeah, my lug nuts are tight.
Old Jun 14, 2006 | 12:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Brightside &raquo;</TD></TR><TR><TD CLASS="quote">Apparently this has happened to a lot of people on clubrsx. The fix seems to be silencer tubes from the mdx. I am going to call acura to see what the deal is.</TD></TR></TABLE>
That's exaclty what my invoice said after the repair. Silencer Tubes MDX.
Old Jun 14, 2006 | 04:02 PM
^^^Can you tell me your experience with the repair, and the dealer. I really want this taken care of.
Old Jun 14, 2006 | 06:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Brightside &raquo;</TD></TR><TR><TD CLASS="quote">^^^Can you tell me your experience with the repair, and the dealer. I really want this taken care of.</TD></TR></TABLE>
Sure. The first time I had it repaired it wasn't fixed and I took it back in less than 400 miles. The second time they got it right and it was fine.
The ticket says, "C/S popping noise from front suspension - see bulletin attached out of spec
414099 diagnosis for front end clunk and repair front end
497 WA94
FC: 03214 Part # count
Second ticket said:
C/S Knocking Noise from Left front area cause:
Internal 414199 removed springs and installed silencer tubes 497 WA94
2 52442-S0X-A01 Silencer Tube
FC:01801
Part # 52442S0XA01
7803 Spring Rubbing 414121 5B4 1.0 Installed Silencer Tubes on both springs
This was done at Acura of Orange Park in Jacksonville, FL. Car had 7,000 miles at time of repair. Car now has 25,000 +.
Hope this helps.
Old Jun 15, 2006 | 07:07 AM
That helps a ton, Thanks.
Old Jun 15, 2006 | 08:22 AM
dc5 kid's Avatar
my car does the same thing, i have a 02 and its cuz my spring is rubbing against the bolts on the top part that goes through the strut tower... it pops really loud when i turn, and if it pops when i turn left, my car will pull left until i turn right again, same thing with the right side.... i dont know if your car does that too or not, but it is most likely your suspension, or steering components
Old Jun 15, 2006 | 03:26 PM
Default Re: Popping noise while steering (dc5 kid)
Mine is a subtle pop, the suspension doesn't feel wrong, but i can hear the noise coming from the suspension.
Old Jun 19, 2006 | 06:37 PM
sleepless247's Avatar
I find that this is always a helpful site. Poke around the site its crazy the TSB's that come up especially with FORD! They also have recalls and other handy info also.
http://www-odi.nhtsa.dot.gov/c...h.cfm
Old Jun 19, 2006 | 09:03 PM
Auex's Avatar
Default Re: Popping noise while steering (sleepless247)
Same problem, 03 ep. From what I have read it is common.
Old Jun 19, 2006 | 11:30 PM
Default Re: Popping noise while steering (Auex)
thanks for all the help
