so i spun a bearing
Old Jun 12, 2006 | 01:55 PM
richeybrooks's Avatar
Default so i spun a bearing
crank is scared but the rods do not look that dammaged, other than getting hot, can i reuse them?
has anyone reused rods before?
thanks
Old Jun 12, 2006 | 02:14 PM
rextec's Avatar
they sometimes warp from getting too hot. take them to a machine shop so they can check them out, then if nesesarry get the big end resized.
Old Jun 12, 2006 | 02:19 PM
hondaguyef's Avatar
Default Re: (rextec)
IMO, replacing the rod is the best option. Individually they are inexpensive(Eagles are like $100 shipped ea.) and the piece of mind you'll have is worth the cost.
Spun bearing(s)= Replace crank and affected rod(s).
Phil
Old Jun 12, 2006 | 04:09 PM
hotimportcrx's Avatar
Default Re: (hondaguyef)
The rods probably only have heat marks on them ...but most likely there out of round....i spun bearings with eagle rods and all four were out of round but i had them resurfaced and put back to oem spec (in roundness)....for using oem bearings...it only cost me 75$ at a machine shop....and after that they...took 9k rpm like a champ...never had a problem again.
AFAccord
Aug 3, 2015 03:26 AM
GoldLudeRay
Sep 13, 2008 03:51 AM
DCRB
Sep 1, 2008 08:42 AM
nicklk
Feb 9, 2004 06:41 PM
EKweezy
Oct 8, 2003 10:09 AM
