Tranny or clutch problem?
Old Jun 12, 2006 | 10:34 AM
cupOjo's Avatar
Default Tranny or clutch problem?
Ok so i start my car the other day and it just didnt seem to want to go into gear, it grinded when i put it in R . I turned it off and tried to start the car with it in gear it starts up but than jumps forward as if it wants me to drive it, but wont let me take it back out of gear. I tried to tighten the clutch cable as much as i could but still nothing. I just bought my car about a month ago and i know nothing about what is happening. Can anybody help me out at all? I need my car back on the road. Also i have a 93 GSR if that helps at all im not sure??
Old Jun 12, 2006 | 05:40 PM
Bense's Avatar
Default Re: Tranny or clutch problem? (cupOjo)
when you push the clutch in, it should "disconnect" the engine from the transmission. even if your clutch is dead, or your transmission is dead, you should be able to disconnect them.
are you sure that it's not the cable?
Old Jun 12, 2006 | 11:39 PM
MaxEfficient's Avatar
Dude that's a clutch issue. It's not disengaging. If you've eliminated the possibility of it being the cable, you're gonna have to drop the tranny and replace the clutch. Fun stuff...
Old Jun 13, 2006 | 10:39 AM
cupOjo's Avatar
Default Re: Tranny or clutch problem? (Bense)
Ya see thats my problem i have no clue how to tell if it is the clutch cable or what? I know you guys probly dont want to sit here and tell me how to fix my problems, but if you could send some pictures of what ur maybe talking about? If not its cool i just really wanna find out what it is its pissing me off!! If nobody can help me i guess i should just get it towed the shop and have them diagnose whats wrong..
Old Jun 13, 2006 | 01:20 PM
JimBlake's Avatar
Have someone press the clutch pedal repeatedly while you watch under the hood. Does the cable pull the throw-out lever properly? Measure how far it moves back & forth. Someone here might know how far it's SUPPOSED to move (not me, mine are hydraulic).
If you see the cable moving things properly, then the problem MUST be inside. Sometimes the clutch disk breaks up so pieces of it wedge in the pressure plate. That sounds like what's happening here.
Old Jun 19, 2006 | 01:09 PM
cupOjo's Avatar
Default Re: Tranny or clutch problem? (JimBlake)
So as my clutch problem pisses me off, i have come across a different problem today.. i tried to start my car and it doesnt want to turn over for some reason. Ive started it everyday cuz its sits in my drive way and before it seemed like it was hesitant to start and today i doesnt start at all, clutch problem? Or Battery? bump for some advice!
Old Jun 19, 2006 | 03:27 PM
boost_lee's Avatar
if it is as what you are saying that clutch engagement, and cant shift while the car is on, then meaning you need to RE-Bleed the Master Cylinder. Leaking or bad master cylinder, not enough fluid pressure for clutch to engage, just re-bleed it.
Old Jun 19, 2006 | 03:36 PM
cupOjo's Avatar
Default Re: Tranny or clutch problem? (initial_si)
I have no idea how to do that? Also what about how its not starting could that have something to do with the clutch or is a hole different problem?
Old Jun 19, 2006 | 03:47 PM
boost_lee's Avatar
to re-bleed the clutch, you will need 2 people. One to pressure the clutch back-fourth, one underneath the car to loosen-tighten the nut from the trans. Have you ever seen or done a Brake swap/Change? And when someone has to press the clutch back and fourth, stop, etc repeatedly? Same thing in the clutch, just that you need to find the nut of the trans to re-bleed it from..Its easy trust me, a 1yr can do it as long as you can find that nut to loosen/tighten while the person in the car is stepping on the clutch to cause pressure release.
As for not starting, are you pressing the clutch all the way? There may be no clutch engagement.
Old Jun 19, 2006 | 06:17 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cupOjo &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea how to do that? Also what about how its not starting could that have something to do with the clutch or is a hole different problem?</TD></TR></TABLE>What initial_si is saying is for a hydraulic clutch. You said yours is cable, right?
The clutch pedal should have a switch that prevents you from starting unless the clutch is disengaged (pedal down).
The problem with not starting could be as simple as a dead battery. That would explain the weak starting before, & not starting today. It could be the clutch switch, but that would be all-or-nothing.
Old Jun 21, 2006 | 06:45 PM
cupOjo's Avatar
My car is running fine as i moved into my garage becuase it was sitting so long. Now i push the clutch all the way in and the car starts but wont go into gear? I think im going to just take it to a shop and let them deal with it, because i know nothing about fixing my car myself yet?
Old Jun 22, 2006 | 10:10 PM
MY EJ6's Avatar
IM HAVING THE SAME PROBLEM I DRIVE A 97 DX WITH A B16A2 I JUST CHANGED THE AXELS AND THE PROBLEM STARTED RIGHT AFTER I TOOK IT FOR A TEST DRIVE GOT A NEW CLUTCH MASTER CYILINDER AND STILL HAVE THE SAME PROBLEM IM GOING TO REBLEED IT TO SEE IF IT MAKES A DIFERENCE I HAVE A HYDRO CLUTCH PLEASE HELP
Old Jun 27, 2006 | 10:04 PM
MY EJ6's Avatar
Default Re: (97 SIR dx)
I need help somebody please
Old Jun 28, 2006 | 10:04 PM
MY EJ6's Avatar
HELP
Old Jul 1, 2006 | 07:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 SIR dx &raquo;</TD></TR><TR><TD CLASS="quote">IM HAVING THE SAME PROBLEM...</TD></TR></TABLE>Describe what happens; cupOjo had a couple different things... Besides, he's got a cable clutch & you've got a hydraulic clutch. Did bleeding it make any difference?
WagoCan_Brownie
May 27, 2012 08:30 AM
2000Accord5sp
Dec 11, 2008 10:39 AM
speedfreek128
10
Mar 28, 2008 07:45 PM
EJ1_228
May 14, 2006 09:51 AM
im_your_dad
Apr 17, 2006 03:29 PM
