Oil filter Question for SIR B16A
Old Jun 12, 2006 | 07:35 AM
B16CivicEX's Avatar
Default Oil filter Question for SIR B16A
hey guys i just bought a 2000ex with a b16A, was told is a SIR becasue of liitle things like not vacume line to connect cruise and few others, My questions is i bought a regualr oil filter for a 2000si with a b16a2 , and it leaks around the seal under high rpm's i took it off to insure i did not have 2 seals, and i dident, so i went back and got another brand of filter, fram, and same thing.. has anyone ever heard of this motor requiring a differnet filter?
Old Jun 12, 2006 | 07:48 AM
sheBangZ's Avatar
Default Re: Oil filter Question for SIR B16A (AirForceB16)
sounds odd. I have a sir2 also and just use the b16a2 oil filter no problem. are you sure the thread might not be stripped causing the filter to not go all the way in? I use purolator, try that to see if it would work. A common mistake i see the autozones and such do is when i say si, they punch in ex so i get a d series filter instead of b. watch the screen when they pull it up to make sure it says b16a2.
Old Jun 12, 2006 | 07:53 AM
RockLee`'s Avatar
i have a sir2 b16a just like you, i use regular fram/stp/whatever brand that is listed for the DEL SOL VTEC and 2000 Si... same filter...
i have no problems, i just hand tighten the filter... make sure you oil up the rubber rings before putting the filter in... or maybe its your blok in the filter area that has something fucked up about it...
no special filter needed for jdm...
Old Jun 12, 2006 | 08:06 AM
tatmark1's Avatar
Default Re: Oil filter Question for SIR B16A (sheBangZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ &raquo;</TD></TR><TR><TD CLASS="quote">. A common mistake i see the autozones and such do is when i say si, they punch in ex so i get a d series filter instead of b. watch the screen when they pull it up to make sure it says b16a2. </TD></TR></TABLE>
They are same part number(same part) DUH
Old Jun 18, 2006 | 10:58 AM
sheBangZ's Avatar
so b and d series oil filters are the same huh? you sir are a moron.
Old Jun 18, 2006 | 11:06 AM
Lewy. Dee Ayy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ &raquo;</TD></TR><TR><TD CLASS="quote">so b and d series oil filters are the same huh? you sir are a moron.</TD></TR></TABLE>
could be true..the oil filer off my d15 works on a 93 subaru legacy. same part #...who woulda thought?
Old Jun 18, 2006 | 11:07 AM
EG2Driver's Avatar
seems like ur the moron.....my bro's d and my b both use the same 3593 Fram oil filter.
Old Jun 18, 2006 | 11:11 AM
ek99's Avatar
Default Re: Oil filter Question for SIR B16A (WhiteOut)
B and D oil filters are the same. Just search.
Old Jun 18, 2006 | 12:48 PM
tatmark1's Avatar
tatmark1's Avatar
DUMB *** KIDS NEED TO KEEP DUMB *** MOUTH SHUT!
STUPID F@CK<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheBangZ &raquo;</TD></TR><TR><TD CLASS="quote">so b and d series oil filters are the same huh? you sir are a moron.</TD></TR></TABLE>
Old Jun 18, 2006 | 01:55 PM
Jimmy's Avatar
Global Moderator
Default Re: Oil filter Question for SIR B16A (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 &raquo;</TD></TR><TR><TD CLASS="quote">B and D oil filters are the same. Just search. </TD></TR></TABLE>
MY GOD THANK YOU!!!!!!!!!!
Old Jun 18, 2006 | 02:52 PM
ballerchild's Avatar
Default Re: Oil filter Question for SIR B16A (tatmark1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatmark1 &raquo;</TD></TR><TR><TD CLASS="quote">DUMB *** KIDS NEED TO KEEP DUMB *** MOUTH SHUT!
STUPID F@CK</TD></TR></TABLE>
OUCH!!
Old Jun 18, 2006 | 03:00 PM
Out of every
Default Re: Oil filter Question for SIR B16A (ballerchild)
k series also fits
edit** i always use rsx type s filters on my b. supposedly higher oil pressure due to how small the filter is a friend recommended it, i tried it and it worked
Modified by e gee two at 4:18 PM 6/18/2006
Old Jun 18, 2006 | 06:09 PM
See Are Ex's Avatar
what benefits would higher oil pressure yeild?
Old Jun 18, 2006 | 06:40 PM
jdeemseerx's Avatar
looks like your the *** sir.. i work at honda and the only car that requires a different filter is the S2000 other than that there all the same size D, B, H, K series doesnt matter so once again ***
Old Jun 18, 2006 | 06:48 PM
FalkenSiR's Avatar
Default Re: (jdeemseerx)
Enough with the bullshit ladies.
Buy OEM
Old Jun 18, 2006 | 06:50 PM
Wicked-Civic's Avatar
aight man i work at a shop that does oil changes lol. The filter number from Fram is either a 7317 or a 3593A try both of those one should work.
Adankid
Jan 1, 2009 03:12 PM
KevTegGSR
Mar 1, 2008 03:32 PM
trianglegreg
Nov 19, 2005 12:54 PM
handa
Aug 4, 2004 12:45 PM
Roky
Jan 23, 2004 04:29 PM
