Canadian 99-00 SiR comes with 15/16" master cylinders?
I thought the SiR was the same as the US '99-'00 SI's, which come with the same 7/8" master cylinder as the US EX's.
If the Canadian SiR's really come with 15/16" master cylinders, will it bolt into 99-00 Civics without ABS? Specifically, bolt onto the brake booster and all brake lines bolt on without rebending?
Because the sir had abs, the si didnt
So...youre going to have that larger fitting issue.
Its not a big deal to cut the end off, replace with an abs size fitting, and re-double flare the line - autozone even rents flare sets
spooncivic1
May 3, 2006 09:38 PM
Another Drew
Jul 4, 2005 06:35 PM
