CTR pistons , rods...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkey1 »</TD></TR><TR><TD CLASS="quote">mm, are they really that bad ?</TD></TR></TABLE>
i think they were only meant to work in a B16B shortblock...i.e. CTR shortblock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkey1 »</TD></TR><TR><TD CLASS="quote">Hey ppl
i have some CTR pistons that i have got to ut in my itr block,
however i aint got some rods.
im finding it difficult to source some b18c /4/5/6 rods..
what would be the best solution with as little modification..
i was thinking of eagle rods but there happens to be alot of modifications involved.. could someone put light on this?
cheers ppl</TD></TR></TABLE>
You can also use regular GSR P72 connecting rods. I recomend adding some ARP rod bolts for good measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">those pistons are harsh on cylinder walls dude...detonation is not a good thing
that issue is easily fixed with larger injectors, EMS, and Tuning
i think they were only meant to work in a B16B shortblock...i.e. CTR shortblock </TD></TR></TABLE>
B16B short block is identical to any B18C short block except for the crank and rods
</TD></TR></TABLE>that issue is easily fixed with larger injectors, EMS, and Tuning
would 310 injectos be ok (rc) and will i have to get a resistor box for it??
would do you guys think of me getting an oil catch can?
and do many people use oil coolers as someone recomended using one
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkey1 »</TD></TR><TR><TD CLASS="quote">would 310 injectos be ok (rc) and will i have to get a resistor box for it??</TD></TR></TABLE>
yes they would suffice and you dont need a resistor box either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkey1 »</TD></TR><TR><TD CLASS="quote">would do you guys think of me getting an oil catch can?</TD></TR></TABLE>
good idea on all builds
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkey1 »</TD></TR><TR><TD CLASS="quote">do many people use oil coolers as someone recomended using one</TD></TR></TABLE>
not needed unless you will be road racing it for long periods of time
