Baking our headlights
Old Jun 11, 2006 | 09:23 PM
T2C's Avatar
T2C
Default Baking our headlights
Has anyone done this before? Please post info I should know and pics too if possible. I did this to my both of my previous civics, just wondering if the integra would be the same thing. Thanks!
post to the DIY that I used for my civic:
https://honda-tech.com/zerothread?id=812732
After I get this done I will make a DIY post with pics as well
Old Jun 11, 2006 | 10:20 PM
erikiksaz1's Avatar
Default Re: Baking our headlights (T2C)
Same procedure. The only thing that'll probably be different is the time needed to soften up the sealant. Make sure you realign your headlights afterwards!
Old Jun 11, 2006 | 10:35 PM
Reid's Avatar
Global Moderator
Are you going to bake the headlights to install HID projectors or just paint them black to make them "JDM TYPE R" style?
Old Jun 12, 2006 | 01:28 AM
Mires's Avatar
Default Re: Baking our headlights (Reid)
Please don't do that to your headlights. It just doesn't look right on Integras unless you are talking about JDM sir headlights. I don't understand why you would have those though.
Old Jun 12, 2006 | 06:11 PM
mrlegoman's Avatar
Default Re: Baking our headlights (Mires)
FYI: Don't use "Gasket Cleaner/Remover" on you headlights. It will melt the plastic.......
Old Jun 12, 2006 | 06:23 PM
Jon D's Avatar
use a heat gun.... much better process!
Old Jun 13, 2006 | 04:27 PM
E46Kid's Avatar
Default Re: Baking our headlights (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 &raquo;</TD></TR><TR><TD CLASS="quote">Same procedure. The only thing that'll probably be different is the time needed to soften up the sealant. Make sure you realign your headlights afterwards!</TD></TR></TABLE>
Old Jun 14, 2006 | 11:02 AM
T2C's Avatar
T2C
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Are you going to bake the headlights to install HID projectors or just paint them black to make them "JDM TYPE R" style?</TD></TR></TABLE>
They are the 4 circles with 8000k hids, I just want a new look before I do the jdm conversion, still deciding on whether or not I want to do this tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mires &raquo;</TD></TR><TR><TD CLASS="quote">Please don't do that to your headlights. It just doesn't look right on Integras unless you are talking about JDM sir headlights. I don't understand why you would have those though.</TD></TR></TABLE>
Do you have a pic? I want to see if its as ugly as you say
Old Jun 15, 2006 | 08:21 AM
00ITR #543's Avatar
Did it on my usdm headlights to retro-fit hids. Pre-heat oven to 400. Turn off oven and put headlight on a baking pan and place in the over for 10 minutes. Pull it out and the headlights crack open pretty easily.
CPreston
Mar 21, 2009 06:00 AM
imsickofrice
Paint and Body
18
Feb 3, 2009 05:17 PM
JDM02em2
Honda Civic (2001 - 2005)
Jan 19, 2009 07:45 PM
Jaypee
Jan 1, 2004 01:14 AM
