B16 B18 Idle Air Control Valve Block-off Plate question
Old Jun 11, 2006 | 07:30 PM
streetsold6teeny8's Avatar
Default B16 B18 Idle Air Control Valve Block-off Plate question
has anyone here heard of this b4. Is it good i never heard of it and wanted to know b4 i bought it.
Old Jun 11, 2006 | 07:54 PM
93CX's Avatar
Default Re: B16 B18 Idle Air Control Valve Block-off Plate question (streetsold6teeny8)
Its fine if you live in Cali and dont need an IACV
Old Jun 11, 2006 | 08:08 PM
CBEengineering's Avatar
im interested also
Old Jun 12, 2006 | 09:02 AM
w/e ima buy it its looks functional and not like a bad idea
Old Jun 12, 2006 | 09:40 AM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetsold6teeny8 &raquo;</TD></TR><TR><TD CLASS="quote">has anyone here heard of this b4. Is it good i never heard of it and wanted to know b4 i bought it.
I'll stick to my peice of sheet metal inbetween it.
And thats not your idle air control valve, its your Fast Idle Thermo Valve.
Old Jun 12, 2006 | 08:32 PM
Thanks mines is bad so im jus putting this on.
Old Jun 12, 2006 | 08:48 PM
dutchman5's Avatar
i m interest...where did u get that from?
Old Jun 12, 2006 | 08:53 PM
i just bought it last nite on EBAY i was surprised too with it lol but i will post up when i install it and tell you guys if its good or not. it was inexpensive. paid 26 for it brand new..
Old Jun 14, 2006 | 07:03 PM
will be posting up soon if this **** is good or not
Old Jun 14, 2006 | 07:05 PM
.:Swig:.'s Avatar
if its good ill just fab one up
Old Jun 14, 2006 | 07:10 PM
VTcivicHB's Avatar
Tin soda can does the same exact thing. Screw paying actual money for sheet metal when it does the same thing.
-Dan
Old Jun 14, 2006 | 07:18 PM
Well its actually a thick plate pretty thick not sheet metal.
Old Jun 14, 2006 | 07:20 PM
nekoabandoned's Avatar
Default Re: (streetsold6teeny8)
i buy blocks of alum. just for **** like this.
Old Jun 14, 2006 | 07:30 PM
i dont got materials for it so i just bought it w/e
Old Jun 17, 2006 | 09:40 AM
Ok b4 you install the block-off you have the the FITV (Fast Idle Thermo Valve) under the throttle body. This is only connected to one hose which goes to the motor. Then right on top of the FITV is another hose not connected to the FITV but to the TB and it goes to the IACV((Idle Air Control Valve) in back on the intake manifold. Well with the block off plate all you do is remove the hose going from the top of the FITV to the IACV. Then the other hose which goes from the FITV to the motor needs to also be removed because you'll need a longer one to run it straight to the IACV. You'll have the hose going from the engine to the IACV instead of going to the FITV then to the IACV. Since there is no FITV anymore you will have the little tube or w/e on top of the FITV open. You can close it or leave it open. I left mines open. And of course install the block-off. End result was fine it worked fine.
This is for whoever is interested. isnt hard to do jus posted in case anyone was curious.
Old Jun 17, 2006 | 12:26 PM
thanks for the info dude
Old Jun 17, 2006 | 02:32 PM
no prob !! oh also the thread title says b16 b18 i dont got a dohc so you ppl know, it worked on the sohc (i would assume any sohc) since the throttle body is the same( mounts the same way)
Old Jun 18, 2006 | 03:42 AM
broketuner-Sol_Si's Avatar
So what's the benefits/consequences of this piece?
Old Jun 18, 2006 | 07:13 AM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default Re: (broketuner-egb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">So what's the benefits/consequences of this piece?</TD></TR></TABLE>
I wanna know too.
Old Jun 18, 2006 | 03:26 PM
That i didnt have to buy another FITV and more space in dat section i guess. Also an FITV is expensive.
ShatiaNichols
Jan 31, 2012 08:15 PM
Armed Ferret
Dec 22, 2004 11:19 PM
Vtecless212
Mar 30, 2003 12:33 PM
