shifting problems
Old Jun 11, 2006 | 06:22 PM
allmotorbl's Avatar
Default shifting problems
I've been having some shifting issues. First my tranny starts grinding at high rpms in 3rd n 4th then that goes away now it wont go into any gears unless i shut off my car and put into gear then when i do that n start my car it shakes wildly and my car moves forward with clutch pedal press all the way down. and when it does go into gear its very difficult to shift into or car dies. HELP PLZ
Old Jun 11, 2006 | 06:47 PM
JDM-EJ1's Avatar
Default Re: shifting problems (allmotorbl)
How's your tranny fluid?
Old Jun 11, 2006 | 06:52 PM
AzHonda's Avatar
ok, it sounds like you need a new clutch. cost varies from $350-$500 not including labor fee's.......... a quick fix, would be to learn to shift with your rpms.....
Old Jun 11, 2006 | 08:13 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: shifting problems (AzHonda)
clutch isn't fully disengaging....either clutch assembly is bad or check the hydraulic components. Do you have normal pedal movement? Check the fluid level in the resevoir next to the master cylinder.
Old Jun 11, 2006 | 08:25 PM
stock_honda_coupe's Avatar
Default Re: shifting problems (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">clutch isn't fully disengaging....either clutch assembly is bad or check the hydraulic components. Do you have normal pedal movement? Check the fluid level in the resevoir next to the master cylinder.</TD></TR></TABLE>
Old Jun 11, 2006 | 08:47 PM
3.point.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzHonda &raquo;</TD></TR><TR><TD CLASS="quote">ok, it sounds like you need a new clutch. cost varies from $350-$500 not including labor fee's.......... a quick fix, would be to learn to shift with your rpms..... </TD></TR></TABLE>
you can get exedy OEM replacements for much cheaper than that. try gripforce.com or clutchcityonline.com. they both cell the Exedy OEM clutch kit which includes the clutch, pressure plate, and throw out bearing for around $120.
Old Jun 12, 2006 | 02:15 AM
allmotorbl's Avatar
I filled my tranny fluid an hour b4 all that mess happened
Old Jun 12, 2006 | 02:16 AM
allmotorbl's Avatar
I have new act clutch and fidanza flywheel along with a fully built gsr itr tranny 90% new parts
Old Jun 12, 2006 | 02:18 AM
allmotorbl's Avatar
Default Re: shifting problems (stock_honda_coupe)
Clutch movement is pretty normal engages slightly lower than b4 (professionally installed)
Old Jun 12, 2006 | 02:19 AM
allmotorbl's Avatar
Clutch master cylinder fluid level is fine but its black for some reason. I'm wondering if it could be my clutch master or slave cylinder.
Old Jun 12, 2006 | 03:18 PM
If its black it may have been in there too long and POSSIBLY may have ruined your seals. Although with ruined seals your clutch would work and then slowly engage as fluid leaks by the seals.
antoneexx
Apr 6, 2007 01:50 PM
dc2gsr96
Apr 25, 2006 09:17 PM
pyrus
11
Mar 31, 2005 03:14 PM
k20em2
Mar 19, 2005 04:53 PM
40oztoFreedom
Jun 3, 2004 11:40 AM
