deburning a fuel map???
Old Jun 11, 2006 | 02:38 PM
cbmprelude's Avatar
* B A N N E D *
Default deburning a fuel map???
Is it possible to take and the basemaps already on an ecu and copy them to bring into chrome?
Old Jun 11, 2006 | 03:14 PM
Turbo_y8's Avatar
Default Re: deburning a fuel map??? (cbmprelude)
thats confusing
Old Jun 11, 2006 | 04:11 PM
JDMlyfestyle's Avatar
its possible if the maps were made in crome.
You need a reader/burner before you could do that.
if the chip was made with some other program then it will not load up in crome
Old Jun 11, 2006 | 05:23 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (JDMlyfestyle)
Sorry if I made it confusing. I have a burner and a chipped p28. But I want to take the basemaps off a stock ecu, and take them into chrome to modify them.
Old Jun 11, 2006 | 05:33 PM
Default Re: (cbmprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbmprelude &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if I made it confusing. I have a burner and a chipped p28. But I want to take the basemaps off a stock ecu, and take them into chrome to modify them. </TD></TR></TABLE>
you cant extract a basemap straight from the ECU's program.
Now you can take the program off the of the chip.
BTW Crome already has plenty of basemaps out there so why dont u just use one of those?
Old Jun 11, 2006 | 05:38 PM
cbmprelude's Avatar
* B A N N E D *
how do you take the program off the chip? I need the basemaps for p2n and can't find it, maybe I'm looking in the wrong places?
Old Jun 11, 2006 | 05:39 PM
what motor do u need a basemap for?
Old Jun 11, 2006 | 05:44 PM
cbmprelude's Avatar
* B A N N E D *
96-00 manual trans hx. I am swapping a d16y5 (HX) head on my y7. I am currently making a peppy high mpg daily driver.
Old Jun 11, 2006 | 05:48 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbmprelude &raquo;</TD></TR><TR><TD CLASS="quote">96-00 manual trans hx</TD></TR></TABLE>
the best bet for a basemap would be using a 303stock bin, the timing and fuel will be very similar to the p2n. i would tune afterwards, but it will get you by for now.
Old Jun 11, 2006 | 05:51 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (schardbody)
where can I get this 303 bin? I am tructing you because your sig says vtec-e, so I am assuming you have experience with vtec-e. have you ever ran you z1 with a chipped ecu. is the 303 bin what you used? What are the difference between the 303 and the stock hx basemap?
Old Jun 11, 2006 | 07:05 PM
mathieucivic's Avatar
pgmfi.org
there you find all the .bin file you need.
for my b16c i use uberdata 1.7 is better than crome
Old Jun 11, 2006 | 07:06 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (mathieucivic)
I have been asking aroudn on pgmfi but to no avail
Old Jun 11, 2006 | 07:11 PM
Bense's Avatar
You're talking about dumping the ROM to a .bin file (this is computer geek stuff)
stock core dumps:
http://www.pgmfi.org/twiki/bin...Codes
Yeah, i'm confused on how to handle the d16y5 stuff. We need to get a bunch of people to keep creating threads on pgmfi to get them to do a rom dump.
Old Jun 11, 2006 | 07:20 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Bense)
yea I created a few over there, I was wondering if there was a way get what we need from a stock p2n ecu, cause I will buy one then
Old Jun 11, 2006 | 07:21 PM
schardbody's Avatar
Default Re: (Bense)
well, its not that easy, dumping the rom in the p2n is more complicated than say a p2p or p28 or what have you, so you might not get as much help. anyways. as for the differance in the 303stock and p2n maps, i cant say because i cant find a p2n map either. i can only say the 303 ignition maps are safe enough to run on while untuned, well, more safe than a modified p2p or something else. they share many of the same attributes, vtec e, vtec crossover, etc, etc... main differance is head flow, the y5 head uses a y8 casting, so it flows alot better than the z1 head, which will require more fuel. i am also pretty sure the HX uses 240cc injectors, unlike the z1 which uses 190's.... i am currently running a z1 w/ bypassed egr, open loop (no o2 at all) and still getting 38mpg all city driving. people shunned me for trying it, said it wouldnt work, what have you, but it is fine. boost is next month. good luck, if you need help w/ vtec e bense or I should be able to answer pretty much any question you can think of.
Old Jun 11, 2006 | 07:25 PM
cbmprelude's Avatar
* B A N N E D *
man I should be living in south carolina in vtec-e country
Old Jun 11, 2006 | 07:33 PM
schardbody's Avatar
haha, vtec e not by choice on my part, well, i would run a y5 if the oil pump didnt suck, but the z1 is just useless. boosted will be funner, but basically a hold me over.
Old Jun 11, 2006 | 07:34 PM
Bense's Avatar
i'm sure that if we buy a stock p2n ecu, and offer to mail it to a ecu person, as well as paypal them like $20 , we can get it. I wouldn't mind pitching in a few.
Old Jun 11, 2006 | 07:36 PM
HamiltonRex's Avatar
Default Re: (Bense)
Im not even going to read.. Responce to original Q...
Crome comes with a P28 base.. You just load it and crome.. And you can edit if you want and burn it to a chip.
Old Jun 11, 2006 | 07:37 PM
Bense's Avatar
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Im not even going to read.. Responce to original Q...
Crome comes with a P28 base.. You just load it and crome.. And you can edit if you want and burn it to a chip.</TD></TR></TABLE>
um, so who's the fool here then?
Old Jun 11, 2006 | 07:39 PM
Bense's Avatar
Default Re: (Bense)
http://forum.pgmfi.org/viewtopic.php?p=70057
schardbody's Avatar
bense, hit up chris harris (xenocron) hes a cool fella, i just shipped him my p07 to do some testing on, so he can probably help you out more than anyone else.
Old Jun 11, 2006 | 07:40 PM
Bense's Avatar
Default Re: (Bense)
the more voices I have, the quicker **** gets done.
Old Jun 11, 2006 | 08:01 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (Bense)
bump
Mingo
10
Sep 12, 2008 12:07 PM
dr@ke
15
Oct 27, 2006 09:46 PM
MI4$DC5
May 18, 2005 02:57 PM
HOND PWR
Jul 22, 2003 05:44 AM
