Overheating
No way to know how much to fix the leak until the leak is found.
have you found any fluids on the ground under the car?
Checked along the top of the radiator tank for seepage?
Look at the end of the water pump to see if the weep hole is puking?
White smoke billowing out behind the car when driving?
had a similar problem on my accord...took it in and found out that the radiator was all rotted away on the bottom...I thought it was a line to..because there was coolant on the cement after i filled it up....it was the original radiator in the 9 year old car so it didnt suprise me...check it out.....
poorman's type-r
Oct 29, 2006 09:18 PM
