Seafoam creepin down, into my engine sector, answers or no?
Old Jun 11, 2006 | 12:26 PM
YoungKadafi's Avatar
Default Seafoam creepin down, into my engine sector, answers or no?
So i sprayed a bunch of deep creep into my PCV valve, and fuel pressure reg ports on my IM. I let it sit for an hour, before starting up my car again. I did this so maybe the heat soak will loosen up some poo, and hopefully ejaculate it out of my rather large exhaust pipe. Well no white smoke came out after i let it all sit. So im thinking, did it creep down, INTO my oil? if so I must drain very swiftly. Is this possible?
Old Jun 11, 2006 | 12:31 PM
JDMlyfestyle's Avatar
Default Re: Seafoam creepin down, into my engine sector, answers or no? (YoungKadafi)
people often add sea foam to the Oil and let the car run so that it cleans the Sludge on the bottom end. Id let the car run for a little bit and then drain the oil.
Old Jun 11, 2006 | 12:40 PM
well i didnt add it to the oil, i just put it in the IM, im just afraid it crept into the oil.
Old Jun 11, 2006 | 12:46 PM
Default Re: (YoungKadafi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">well i didnt add it to the oil, i just put it in the IM, im just afraid it crept into the oil.</TD></TR></TABLE>
if your really concerned that it got into the oil then change the oil.
Old Jun 11, 2006 | 12:49 PM
dang, now i gotta wait till payday to change it.....shoot
Old Jun 11, 2006 | 12:51 PM
SiYouLater's Avatar
Instead of using Deep Creep use the regular seafoam that you add into crankcase/fuel tank/IM. The deep creep is just like carb cleaner basically.
Old Jun 11, 2006 | 12:54 PM
Default Re: Seafoam creepin down, into my engine sector, answers or no? (99FBPSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi &raquo;</TD></TR><TR><TD CLASS="quote">Instead of using Deep Creep use the regular seafoam that you add into crankcase/fuel tank/IM. The deep creep is just like carb cleaner basically.</TD></TR></TABLE>
i use Deep Creep to clean parts of the engine when i disassemble it.
Old Jun 11, 2006 | 01:25 PM
addiction2bass's Avatar
Default Re: Seafoam creepin down, into my engine sector, answers or no? (JDMlyfestyle)
well seafoam is only suposed to sit for like what 5-10min. might have evapurated within an hour....
plus after i start the motor back up after sit time, i let the engine idle and warm up again for a few min and then hold the pedal down to a few K rmps till the smoke starts to die down. then i take it down the country road for a quick spin to realy get it all out....
what ive always done is run some thru the gas tank then after a few days or so many miles, then do the vac line and crank case.....
then drive another 50miles or so and change the oil, filter.
only problem ive ever had was last time i did my truck thru the vac lin, i guess i poured to much at once and made a harsh squile sound. after that... after my trucks warmed up it runs realy doggy on accelerasion, BUT i just havent had time to realy fool with it since i got my civic shortly after trucks been parked since then.
i jus tknow thats not a good sound!
http://s40.photobucket.com/alb...8.flv
decent cloud http://s40.photobucket.com/alb...9.flv
but i have seafoamed my truck half a dozen times.
Old Jun 11, 2006 | 01:52 PM
fmrprojects's Avatar
Default Re: Seafoam creepin down, into my engine sector, answers or no? (addiction2bass)
i alwyas use seafoam and put it in through the brake booster vacumm line while the car is running
Daniel06SI
Honda Civic (2006 - 2015)
Jul 15, 2007 08:01 AM
motormike40
Sep 18, 2006 07:23 PM
Takashi1978
Feb 23, 2006 06:21 AM
hotstuffjsn
Mar 22, 2005 01:58 PM
mixxed
Jun 27, 2003 07:52 AM
