having problem tuning my car with zeitronix 3.5 bar map w/ hondata s100b..
Old Jun 11, 2006 | 12:06 PM
eg:R's Avatar
Default having problem tuning my car with zeitronix 3.5 bar map w/ hondata s100b..
my car show really rich under 1k rpm(around 10. a/f range). even with alot of fuel taken out or adding a lot of fuel. the a/f still show 10a/f range. if the rpm range is above 1k then the a/f will jump to 12 to 14a/f. the auto meter boost guage and my zeitronix display guage does not show the same readings. i don't know which one is the correct numbers to tune off with. one thing about hondata is that it can only support up to a 3 bar map only. so im not sure if my 3.5 map with throw the reading off. anybody having the same problem or use a 3.5 aem style map sensor on any hondata s100b or s200b? help me out
Old Jun 11, 2006 | 01:26 PM
98vtec's Avatar
moderator emeritus
Default Re: having problem tuning my car with zeitronix 3.5 bar map w/ hondata s100b.. (eg:R)
might want to check your wiring on the o2. If there is an open wire, the voltage wont be right and the a/f will reflect that.
Old Jun 11, 2006 | 01:38 PM
eg:R's Avatar
you mean the thick wire that plug from the wideband to the o2 sensor??
Old Jun 11, 2006 | 01:39 PM
98vtec's Avatar
moderator emeritus
Default Re: (eg:R)
no i mean the wiring harness that you run to the ECU harness. Power, ground, signal......etc
you are using a zt2 zeitronix wideband right?
Old Jun 11, 2006 | 04:01 PM
eg:R's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">no i mean the wiring harness that you run to the ECU harness. Power, ground, signal......etc
you are using a zt2 zeitronix wideband right?</TD></TR></TABLE>
yes i have the zt2 wideband, i hav e the wideband wire hook up to the ecu harness. not sure where the white wire goes to.
Old Jun 11, 2006 | 05:39 PM
non-VTEC's Avatar
Default Re: (eg:R)
im having no trouble using the zitronix 3.5bar map sensor running uberdata.
there must be a way you can run the same sensor with hondata....
Todallybuilt
Engine Management and Tuning
Oct 15, 2017 06:18 AM
b20turbocivic
Aug 12, 2010 07:06 PM
1.8T_EG
Feb 14, 2003 10:12 AM
R THIS
Dec 14, 2002 03:39 PM
