93 Si with d16y7 wiring problems
Old Jun 11, 2006 | 12:06 PM
pearlcfcivic97's Avatar
Default 93 Si with d16y7 wiring problems
Ok, I bought a 93 si shell, I had a cx motor sitting around dropped that in got a engine harness from a local shop, put it in and was missing map sensor so I hard wired that into the harness, I blew up the cx messing around on the interstate so I dropped in my d16y7 out of my 97 dx civic that’s getting a swap, I used the obd 1 harness that I got from the local shop, wired up the injectors and the obd 2 dizzy, got everything in I reused the cx ecu, since that’s the only obd 1 I have. I started it and it ran like **** wouldn’t rev about 3500 so I was wiring in the IACV and all the other sensors on the intake manifold, But the wire harness I got from the local shop isn’t matching any wire diagrams that I have or I can find and I don’t know exactly what wire harness I have, so wiring is a huge bitch and for the first time have given up trying to figure something out on my car so if anybody has a obd 1 wire harness already modified for a completely stock d16y7 let me know, also what ecu should I be running and if you got one let me know how much you want.
Old Jun 11, 2006 | 12:14 PM
JDMlyfestyle's Avatar
Default Re: 93 Si with d16y7 wiring problems (pearlcfcivic)
Are you having any CEL? if so please go here to diagnose it.
https://honda-tech.com/zerothread?id=1171263
Did you wire up your Distributor and Alternator correctly? Here is a Diagram
Old Jun 11, 2006 | 12:38 PM
I swapped the alternator and I double checked the dizzy wiring, it was throwing a IACV code but i think i blew the ecu now trying to wire it because now it wont start and the cel light just stays on solid no blinks, yea I have gone through all of them already...
Old Jun 13, 2006 | 07:24 AM
come on guys, someone has got a modified harness and an ecu they want to sell...
Old Jun 20, 2006 | 11:42 AM
Ok so I put the cx intake manifold on the dx motor and wired everything up but it runs like **** with the IAC hooked up and idles great with it un plugged except once the engine warms up the engine has like fuel cut or something acting like a redline at about 3500 rpm the motor just cuts out but before the engine is warmed up will go all the way to redline
Old Jun 23, 2006 | 02:03 PM
well still no luck or help, when I wired up my dizzy I used the helms manual and matched each wire with where each one went, I decided to check out my wiring and compare it to the diagram above and they were different and so I wired it up according to the diagram above and now the car wont start, basically im sick of this so If you have a harness that will plug and play from a 93 si to a d16y7 with cx im and tb, obd 1 alternator and obd dizzy let me know
jdmkid_82
Jun 24, 2006 01:24 PM
Civichatch972
Nov 18, 2003 01:17 PM
92hatchattack
May 6, 2003 02:21 PM
Patron
Mar 11, 2003 10:01 PM
b18c5eg
Dec 23, 2002 02:22 PM
