Compression #1 125 PSI, #2 190, #3 125, #4 150
Old Jun 11, 2006 | 08:55 AM
Anti-Drama Queens's Avatar
Default Compression #1 125 PSI, #2 190, #3 125, #4 150
freshly rebuilt gsr
buddy club 3+ cams
81.75 mm jdm type r pistons
dry compression
1. 125
2. 190
3. 125
4. 150
wet
1. 230
2. 300
3. 240
4. 235
what do u guys think the problem is? rings or valves?
if it was rings...what could of caused it? head was completely redone by a machine shop with supertech valves...there was a fuel pressure spike one time up to about 100psi.....but there was always a bad idle even once the motor was first started....completely bummed right now...alot of money was put into this build...did oil change and there was shavings on the magnetic oil drain plug as well...not ALOT ALOT...but enough...please give some input...any is appreciated
Old Jun 11, 2006 | 09:26 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Compression #1 125 PSI, #2 190, #3 125, #4 150 (mr_ducksauce)
I think it may be the rings. How did you break your motor in? What type of oil are you using? How many miles on the motor since the rebuild?
Old Jun 11, 2006 | 09:28 AM
itr1244's Avatar
Default Re: Compression #1 125 PSI, #2 190, #3 125, #4 150 (mar778c)
mine read 230 180 230 230 and my valves on #2 cyl was leaking both intake and ehx
i dont know abot yours tho
Old Jun 11, 2006 | 10:24 AM
RC000E's Avatar
Default Re: Compression #1 125 PSI, #2 190, #3 125, #4 150 (itr1244)
Compression test is a good gauge, but leakdown will answer more of your questions.
Old Jun 11, 2006 | 10:42 AM
JDMlyfestyle's Avatar
Default Re: Compression #1 125 PSI, #2 190, #3 125, #4 150 (RC000E)
a valve lash adjustment is a good idea.. do the lash and if it doesnt help then go with the leakdown test. or vice versa
Old Jun 11, 2006 | 04:53 PM
well it was rebuilt...but always had a bad idle from start...drove it a little bit...rough idle..did everything to it like played a little with timing and idle screw...got it driveable on the road but always had a rough idle...was gonna bring it in for a tune on monday but wanted to do compression check first...did that and these are the results...leakdown test hard?
30 weight oil for about 20 miles...changed it over to the 5w30, thats when i noticed shavings
Old Jun 11, 2006 | 05:05 PM
if the valve lash is off then that can contribute to a bad idle
Old Jun 11, 2006 | 05:09 PM
yeah...ill check that out tommorrow....thanks for all the inputs though...appreciate it.....is a leak down test hard to do?
Old Jun 11, 2006 | 05:35 PM
if you can do a compression test then you can do a leakdown test
Old Jun 12, 2006 | 12:08 PM
Brick Top's Avatar
Default Re: (mr_ducksauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce &raquo;</TD></TR><TR><TD CLASS="quote">30 weight oil for about 20 miles...changed it over to the 5w30, thats when i noticed shavings</TD></TR></TABLE>
shavings?
Old Jun 12, 2006 | 02:33 PM
yes..kind of like when u remove the drain plug off a transmission from a dodge.....like that
Old Jun 12, 2006 | 03:12 PM
onepoint6i's Avatar
shavings are normal....
theres alot that can cause a rough idle...
how many miles are on the engine?
what was your break in method?
why didnt you adjust the valves when the engine was built..?
and how was there a spike of 100psi of fuel?
thats the worst thing that could happen on a fresh ringed engine...itll flush the oil off the cyl walls...seems like you got a few bugs you should have fixed before initial startup...
Old Jun 12, 2006 | 03:17 PM
well...valves were adjusted already.... .007 intake .008 exhaust according to buddy club specs.....i was still in the breaking in period....and still am right now...about 100 miles now....honestly i dont know how the spike happened, but it did happen...it happened when we couldnt get it to start b/c of the knock sensor plug....i plugged it in and it would not allow the car to start...i think maybe b/c im running a chipped p28.....IT always had a rough idle from the begginning
Old Jun 12, 2006 | 03:41 PM
SiR831's Avatar
did u do the leak down yet?
Old Jun 12, 2006 | 05:36 PM
doing it on wednesday...no time to work on the ride that much
Old Jun 12, 2006 | 07:07 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce &raquo;</TD></TR><TR><TD CLASS="quote">well...valves were adjusted already.... .007 intake .008 exhaust according to buddy club specs.....i was still in the breaking in period....and still am right now...about 100 miles now....honestly i dont know how the spike happened, but it did happen...it happened when we couldnt get it to start b/c of the knock sensor plug....i plugged it in and it would not allow the car to start...i think maybe b/c im running a chipped p28.....IT always had a rough idle from the begginning</TD></TR></TABLE>
thats the worst way to break in a motor..run a chip with all kinds of different fuel/timing maps for a specific engine.....
you may have ruined the rings by doing so...
oh btw the rings are seated already especially if you ran ND 30w oil...
Old Jun 13, 2006 | 05:19 AM
well....its supposed to be pretty accurate....and i wasnt planning on running in on the p28 for too long...was gonna bring it to the dyno once everything ran fine for a a/f tune....but the thing is, til now...its still not running right b/c of the rough idle...ALWAYS had a rough idle...i wanted to get everything running right, then onto the dyno right away for just a/f...then keep breaking it in
Old Jun 13, 2006 | 05:56 AM
Chillinit's Avatar
81.75 mm jdm type r pistons</TD></TR></TABLE>
that odd! I was unaware that size was available. It thought it was only 81mm, 81.25mm, and 81.5 mm!
Old Jun 13, 2006 | 10:55 AM
Brick Top's Avatar
Default Re: (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">shavings are normal....
what shavings are normal? coming from where?
Old Jun 13, 2006 | 02:14 PM
emotionisdead's Avatar
Very Emergency!!
it almost sounds like you washed the rings from being too rich. do you have a wideband?
Old Jun 13, 2006 | 03:23 PM
nope..not yet...it was a chipped p28 from phearable.net.....its aftermarket 81.75mm pistons...safety pistons..hasting rings
Old Jun 13, 2006 | 03:57 PM
Slamaccord's Avatar
Default Re: Compression #1 125 PSI, #2 190, #3 125, #4 150 (emotionisdead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead &raquo;</TD></TR><TR><TD CLASS="quote">it almost sounds like you washed the rings from being too rich. do you have a wideband? </TD></TR></TABLE>
I agree with him.
Old Jun 15, 2006 | 05:10 AM
wideband vs vafc? which one just so i can break in my motor with correct a/f
Old Jun 19, 2006 | 02:07 PM
onepoint6i's Avatar
Default Re: (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">
what shavings are normal? coming from where?</TD></TR></TABLE>
a freshly rebuilt engine will always have shavings in the oil and filter..thats why its good to change it right after the rings seat then @ about 100miles again then @ about 1000 miles once more...most builders have their set times on how many miles to change oil on rebuilt engines...ive heard of some changing it like 5-7 times within 1000miles... :shrugs:
