jdm d15b
Old Jun 11, 2006 | 04:48 AM
sammydigital's Avatar
Default jdm d15b
i just swapped in a d15b and it had a cut harness....i have a 95 civic dx motor went in fine...now i need to know there is a single green wire coming off the vtec solenoid what is this for? and where does it go? i have a p28 ecu
also my car wont start it turns over the plugs are in the right order but it wont go?
when i checked the plugs the were soaked in gas....can my injectors be stuck open....and that is causing the motor to flood out before it gets a chance to fire....
thanks for hte help
sam
Old Jun 12, 2006 | 04:43 PM
Bense's Avatar
Default Re: jdm d15b (sammydigital)
vtec pressure switch. Check the ecu thread sticky in the 92-00 forum. there's a diagram there
sammydigital
Jun 12, 2006 12:32 PM
brockscivic
Oct 26, 2005 05:34 AM
