JUST INSTALLED LS swap....
Old Jun 11, 2006 | 12:46 AM
NVturbo's Avatar
O.G. triple O.G.
Default JUST INSTALLED LS swap....
with a 6-puck clutch. You can go into gears when the motor is off..when it's on, you CAN'T. If you pop it into a certain gear and depress the clutch, you are able to crank the car but UNABLE to change into another gear while the car is moving. HELP ANYONE????
Old Jun 11, 2006 | 01:05 AM
QuangAlang's Avatar
bleed your clutch
Old Jun 11, 2006 | 08:20 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (QuangAlang)
I don't think bleeding the clutch will make a difference. If I had no hydraulic pressure, it wouldn't crank at all with the clutch pedal depress. I'm guessing that my cousin installed the 6-puck clutch backwards.
FeelTheBass
21
Apr 7, 2022 11:41 PM
brandynEG
May 29, 2014 01:57 AM
mikeycivic
Jun 4, 2007 05:32 PM
turboteg96
May 21, 2003 05:46 AM
