Harmonic Damper really needed?
Old Jun 10, 2006 | 07:28 PM
EG civic's Avatar
Default Harmonic Damper really needed?
Is a harmonic damper really needed when making much more power than stock. I see some ppl use it and others dont use it. So is it actually worth the purchase? and does it really protect the bearings that much?
Old Jun 11, 2006 | 07:22 AM
globeDELETETHIS USER's Avatar
Yes it, It protects the crank from vibrations and keeps the cranki spinng straight
You could put an underdrive pulley on instead but, id stay with the harmonic damper
Old Jun 11, 2006 | 07:24 AM
Mikey3000's Avatar
Default Re: Harmonic Damper really needed? (EG civic)
1st, its required by NHRA if you run quicker than 10.99.
2nd, its about high engine speed, not necessarily high horsepower. the dampened pulleys are far superior to the stockers and really decrease internal vibration.
Modified by Mikey3000 at 4:34 PM 6/11/2006
Old Jun 11, 2006 | 12:00 PM
hondakevin21's Avatar
Default Re: Harmonic Damper really needed? (Mikey3000)
Get one of the aftermarket fluid damper crank pulley.
RC's ride
Sep 21, 2005 06:46 PM
airwalk07143
Sep 24, 2004 07:40 AM
Unknwn_1
Jan 13, 2003 05:38 PM
1fastGSR
Jan 18, 2002 03:59 AM
EliteIntegra
Nov 25, 2001 03:01 PM
