axle seal will not stop leaking
Old Jun 10, 2006 | 10:40 AM
97grnrs's Avatar
Default axle seal will not stop leaking
its on a jdm b16 sir trans , new seal was put in 3 times and it still is leaking.. it leaks where the axle spins around in the seal.. i tried everything , new seals and axle and it still leaks a lil every time i drive.. pass side
Old Jun 10, 2006 | 12:12 PM
Flashmn's Avatar
Default Re: axle seal will not stop leaking (97grnrs)
are you sure the seal is the same on US and Japan model trannies?
Old Jun 10, 2006 | 03:03 PM
97grnrs's Avatar
Default Re: axle seal will not stop leaking (Flashmn)
thats what i dont know but it has to be cause it fits tight in the trans and its tight on the axle so i dont see how it can keep dripping every day.. perfectly clean when i install it and all and same thing keeps happening.
Old Jun 10, 2006 | 07:05 PM
0618turbocivic's Avatar
is axle pushed in all way? did you buy from same place all the time or different suppliers? maybe bad seal, did you see it coming from the tranny? i thought it was my seal untill i actually got under car again when was taking downpipe off and seen my axle boot was ripped and looked like it was leaking from the seal but it was my axle boot instead.... does your tranny fluid go down? do you have to refill it alot?
Old Jun 10, 2006 | 07:07 PM
check axle boot
Old Jun 10, 2006 | 07:55 PM
97grnrs's Avatar
Default Re: axle seal will not stop leaking (0618turbocivic)
no def not axle boot . its leaking fluid from the trans . right where the axle spins inside the seal it drips every time i park the car.. not alot but about a half dollar size puddle every time i park .i replaced the seal about 3 times now and the axle .. it fits tight how it should but it always leaks.. i dont have and idea why.
Old Jun 10, 2006 | 09:29 PM
did you push in the axle or tap it in? maybe you tapped it to hard or something but 3 seals should have done it for the seal at least, try taking out the axle and reinserting the axle, i hate leaks lol
TEGMAN89
Jan 11, 2011 05:12 AM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
antz92
Jul 4, 2008 09:15 PM
digital sol
Oct 30, 2004 12:06 PM
See Are X
Oct 21, 2003 09:23 PM
