brake q's
my car is acting funny when i press the brakes, only when it is warmed up real good and been driving for about a hour the brakes go to the floor. i dont know what it could be i need to fix this a.s.a.p please oh and when i sit at at red light or something it seems to leak off..
Sounds like a bad master cylinder. If the pedal is ok when you press it quickly but sinks when you apply a gentile pressure to it, it's usually the master cylinder.
my brake recently just did that too when i am at a stop light, the brake pedal goes straight to the floor and i always had to pump and press to brake...found out it was the master cylinder.... everything was
after the ex master cylinder install
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Sounds like a bad master cylinder. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatch90 »</TD></TR><TR><TD CLASS="quote">ok i am going to change that asap i hope it works
they said that it might be the vacume canister also? should i replace that also?</TD></TR></TABLE>
no, change the M/C first.
mattbatson
Oct 23, 2008 07:30 PM
