Oil Leaks in Ports/ Ex & Int.
Old Jun 9, 2006 | 07:01 PM
regamaster's Avatar
Default Oil Leaks in Ports/ Ex & Int.
OK This on has me stumped.
Can anyone here provide more insight?
Details:
Broke a TODA Timing Belt (stay away this is the 3 time) ALL of the valves; bent.
Replaced all of the valves and had a valve job, all new OEM seals.
-reinstalled the head.
*** Resulted in all the ports on the intake and exhaust side leaking oil.
This time I pulled the head and had new guides installed and another set of Seals
in (Ferrea)
- Reinstalled the head
*** Resulted in the same thing!
Now some other notes:
- plugs are perfect.
- Tops of Pistons are clean and not oily
- Chamber is clean and not signs of Oil
I am completely stumped. I am going to do a leak down, however this will only show the seal capacity of the valves and the top compression ring.
Anyone with other ideas here ?
Old Jun 9, 2006 | 07:42 PM
Ivan's Avatar
senior gold member
Default Re: Oil Leaks in Ports/ Ex & Int. (regamaster)
hmmm weird, maybe the machine shop keeps messing up on the install of the seals. Thats the only thing I could see a problem with. maybe too much crankcase pressure? I don't know without more info.
Old Jun 10, 2006 | 06:06 PM
regamaster's Avatar
Default Re: Oil Leaks in Ports/ Ex & Int. (Ivan)
Leak Down Test was good. only 3 cylinders were @ 0 and 1 @3% loss.
Still good either way
Brian Deane
Feb 11, 2016 07:09 AM
EsotericImage
Oct 19, 2013 06:18 AM
Poordudes TypeR
Sep 13, 2011 09:22 PM
regamaster
Jun 13, 2006 07:52 AM
thehondaguru
Jun 9, 2004 06:09 PM
