What should be my next step?
Old Jun 9, 2006 | 06:31 PM
broketuner-Sol_Si's Avatar
Default What should be my next step?
I was wondering what you guys think as to what would help my car out more when I go to do more stuff to it later this year: a new/better header, cams or doing block work(B/BP, all new seals/gaskets) My budget will be around 750-1000. I've just heard similar results with these totally different mods so I was wondering what you think would keep my car most reliable.
for cams I'm thinking of CTR/ITRs, or the buddy club 3+s, For the header, I'm thinking of rage, profab or spark racing.
full setup is jdm b16a ('92 2nd gen)
injen 3"CAI
AEBS TB
AEBS IM(Ported runnners)
RC 310s
magnecore wires
denso plugs
DC 4-1 stainless header (dented to **** )
2.5" custom mandrel exhaust
Exedy clutch and flywheel
tuned on crome pro by chris of whitfield racing
IF YOU VOTE PLEASE SAY WHY AND WHAT BRAND(S) YOU'D RECCOMEND.
Modified by broketuner-egb16a at 2:39 AM 6/10/2006
Old Jun 9, 2006 | 07:59 PM
Ivan's Avatar
senior gold member
Default Re: What should be my next step? (broketuner-egb16a)
I would do a jdm itr header with some buddy club 3's. SMS even recommends that header for 1.6's.
Old Jun 9, 2006 | 08:44 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: What should be my next step? (Ivan)
What he forgot to metion to you guys is that he currently has an old DC header that has the bottom two tubes crushed. So IMO a header would be the next step because even with larger cams you will not be using the motors full potential with a crushed header... My vote goes for a WhitfieldRacingInc.'s header (rage) as for cams I would rock some blox1's (great price)
Chris Whitfield
Old Jun 9, 2006 | 08:45 PM
Ivan's Avatar
senior gold member
Default Re: What should be my next step? (HOOKUPS)
ahh I see. yeah, those crushed pipes are a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">What he forgot to metion to you guys is that he currently has an old DC header that has the bottom two tubes crushed. So IMO a header would be the next step because even with larger cams you will not be using the motors full potential with a crushed header... My vote goes for a WhitfieldRacingInc.'s header (rage) as for cams I would rock some blox1's (great price)
Chris Whitfield</TD></TR></TABLE>
true... I edited the post to include that, as well as the whole setup so far.
Old Jun 10, 2006 | 03:26 AM
DJslepton's Avatar
definetly a header I would get toda's if its cheaper than the 3 headers you have mentioned and hondata s200
Old Jun 10, 2006 | 10:54 AM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
ctr pistons, forget the balance and blueprinting.
Old Jun 10, 2006 | 03:05 PM
Default Re: What should be my next step? (sleptonEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleptonEH2 &raquo;</TD></TR><TR><TD CLASS="quote">
definetly a header I would get toda's if its cheaper than the 3 headers you have mentioned and hondata s200</TD></TR></TABLE>
Umm. the toda header is one of the most expensive headers on the market, sure it performs but for about 300-400 less I could get a rage or spark racing and have almost as nice of a curve and as much area under the curve. As for hondata, why would I get that I've already got crome pro.
Old Jun 10, 2006 | 11:12 PM
So I guess header is a near unanimous decision. Might be able to get cams at the same time too. I'm thinking of getting a stage 1 type cam, still not too sure what to go with. But I gotta get the $ first.
Old Jun 11, 2006 | 08:02 AM
Top Ramen's Avatar
Default Re: What should be my next step? (candy eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by candy eg &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons, forget the balance and blueprinting.</TD></TR></TABLE>
I completely disagree. You will see more hp for less money with a good header, then cams. There is no reason at all to go into the short block at this point.
Also, the JUN and Toda headers show up used for decent prices sometimes and are both great b-16 headers. The DC sports 4-1 is also a decent header (for the money) for your application when it is not beat up.
Good luck with your project.
racin_fool
20
Aug 7, 2006 12:58 PM
coot_er
16
Feb 13, 2005 12:14 AM
95lstegman
Jan 24, 2005 08:04 PM
asilaydying1984
Jan 3, 2005 09:02 PM
cvrboi
Mar 12, 2004 08:41 PM
