searched but no result....HELP!!!!
Old Jun 9, 2006 | 05:05 PM
89efhatchcrap's Avatar
Default searched but no result....HELP!!!!
ok, im having problems with my hatch. the single cam ZC i have isnt idling like its suppose to. it ran fine up until yesterday. its idling well below 500rpms, and when i get it throttle it like bogs out like hell, then i get this *plump plump* sound...and once its gets going to around 1000rpms its revs up, but not like it used to. and if i hold it steady at 1000rpms, then push the throttle all the way down it bogs then revs up. IDK what the problem is could it be a warpped head??...i cant see any leaks coming out...and theres no check engine light. HELP!!!!
Old Jun 9, 2006 | 08:13 PM
Default Re: searched but no result....HELP!!!! (89efhatchcrap)
bump
Old Jun 10, 2006 | 03:29 AM
661rex89si's Avatar
check your timing and check your tps. better yet check your ecu to see if its throwing any codes. i think you should check those things i stand corrected.
Modified by 661rex89si at 4:59 AM 6/10/2006
Old Jun 10, 2006 | 11:36 AM
Default Re: (661rex89si)
ecu isnt throwing any codes, and my tps sensor is fine. ahhh...im getting frustrated with this!
Old Jun 10, 2006 | 12:00 PM
661rex89si's Avatar
check your timing if it aint none of thy above and you cant figure it out. i dont no whatelse to tell you. but to take it in somewhere to get it checked the sooner you get your car back up and running.
Old Jun 10, 2006 | 12:07 PM
661rex89si's Avatar
anybody else can help this guy out if im wrong.
Old Jun 10, 2006 | 12:11 PM
Rex-Si's Avatar
What about all your Vac lines ?
Map ?
Old Jun 10, 2006 | 12:22 PM
Default Re: (Rex-Si)
a buddy of mine and i checked all the vac lines, they are all hooked up right, no leaks in any lines...map sensor is good. still not throwing any codes...but i did find a massive head leak like 10 mins ago...im thinking its a warpped head?? any other suggestions?...im think im gonna take the head off and have it re-surfaced....would that help?
Old Jun 10, 2006 | 12:24 PM
661rex89si's Avatar
it might help but it would be cheaper i think if you come up on a head on the classifieds there dirt cheap.
Old Jun 10, 2006 | 12:30 PM
Rex-Si's Avatar
Default Re: (89efhatchcrap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efhatchcrap &raquo;</TD></TR><TR><TD CLASS="quote">...but i did find a massive head leak like 10 mins ago...</TD></TR></TABLE>
Old Jun 10, 2006 | 04:48 PM
word! haha yeah once i found the head leak i was like, AHHHH.....its a pretty bad leak the whole back side of the tranny and black are caked in oil and dirt...its not a pretty site....thanks guys
mrmoomoox
May 10, 2010 07:42 AM
neEven
Jan 29, 2005 02:50 PM
EG6 SiR
Jul 11, 2004 10:44 PM
