ignition timing with crome?
Old Jun 9, 2006 | 04:35 PM
an2ny888's Avatar
Default ignition timing with crome?
i'm using crome and i bumped up the idle ignition timing up to 22 degrees in columns 1 to 4. my question is, does my idle timing still have to be at 16 degrees on the crank pulley when i short the cel? i remember reading that somewhere, not sure though
Old Jun 9, 2006 | 07:02 PM
92TypeR's Avatar
FSAE
Default Re: ignition timing with crome? (an2ny888)
We set distributor timing to 15deg before we tune ignition columns on Crome.
Old Jun 9, 2006 | 08:48 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: ignition timing with crome? (92TypeR)
15-16 deg btdc at idle then tune away... But 22 deg at idle??? Wow wierd
Old Jun 9, 2006 | 08:57 PM
an2ny888's Avatar
Default Re: ignition timing with crome? (HOOKUPS)
the pro1's like 22 degrees timing at idle
Old Jun 9, 2006 | 10:41 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">the pro1's like 22 degrees timing at idle</TD></TR></TABLE>
22 degrees timing set via software.
Distributor is 15-16deg.
Do you know how to tune with Crome?
Old Jun 10, 2006 | 12:37 PM
MR_Ek4's Avatar
https://honda-tech.com/zerothread/1655790 hmmmm...is right maybe this explains the numbers on your dyno.
Old Jun 10, 2006 | 04:54 PM
an2ny888's Avatar
Default Re: ignition timing with crome? (EM1_00MRBuilt)
FYI, i'm not doing the tuning, i have a tuner. i'm just asking about this to familiarize myself with the tuning process
gooblinn258
Dec 12, 2013 06:21 PM
josephshark
Jan 2, 2006 11:52 AM
SOHCMAN
May 31, 2005 03:10 PM
handa
Apr 11, 2005 10:36 AM
non-VTEC
Jan 27, 2002 12:15 PM
