Which cable tranny is best?
Old Apr 15, 2002 | 07:00 PM
Hayasa15's Avatar
Default Which cable tranny is best?
I am getting ready to swap a b16 into my civic. I am having a hard time finding information on the cable trannys. Which is best for the b16? What is the difference between the s1, y1, ys1...?
Old Apr 15, 2002 | 07:35 PM
rainforest's Avatar
Default Re: Which cable tranny is best? (Hayasa15)
s1 w/lsd. same gearing as a usdm type r but has bad 3rd gear syncro.
y1 4.2 final longer than the s1 but stronger.
ys1 92-93 gsr tranny same gearing as s1 and strong as the y1.
Old Apr 15, 2002 | 07:56 PM
Hayasa15's Avatar
Default Re: Which cable tranny is best? (rainforest)
So would you suggest the ys1 for a b16? Also it is my understanding that the ys1 would be better because you can kit parts for it easier? Correct me if i am wrong.
Old Apr 15, 2002 | 08:01 PM
rainforest's Avatar
your right.
Old Apr 15, 2002 | 08:02 PM
Hayasa15's Avatar
What can you tell me about the j1?
Old Apr 16, 2002 | 02:39 PM
fire7882's Avatar
I think it is the same as the s1 but with a different final drive ratio.
Old Apr 17, 2002 | 02:59 PM
g's integ's Avatar
yeah, I'm about to swap my '95 LS w/ b18c which has a b16 head. Which cable tranny should I go. Can't really afford a hydro tranny right now. This guy is selling a j1 off 91 b16a for $350. What do you think guys?
Old Apr 17, 2002 | 03:39 PM
bryant's Avatar
Default Re: Which cable tranny is best? (g'sinteg)
J1 and S1 are the same thing, but i think J1's are a bit stonger. But both have the same Gear ratio. YS1 w/LSD or a J1 w/aftermarket LSD would be best. IMO
Old Apr 17, 2002 | 03:56 PM
2K_TEG's Avatar
Default Re: Which cable tranny is best? (CR-X)
Sorry for the newbie question, I don't know **** about trannies. What is the difference btwn hydro and cable? Which came stock with which cars?
Old Apr 17, 2002 | 04:50 PM
bryant's Avatar
Default Re: Which cable tranny is best? (2K_TEG)
Cable clutches came in the earlyer years (??-91) They use a cable to engage and disengage the clutch. They usually wear faster then the hydro clutches.
Hydrolic cluthes came in the later years. (92-Present) Im not real sure on exacly how they work. So i dont want to give you any wrong information. But they do last longer than the cable clutches
Also a cable type tranny is cheaper then a hydro tranny. $$$ wise.
[Modified by CR-X, 7:51 PM 4/17/2002]
Old Apr 17, 2002 | 05:15 PM
2K_TEG's Avatar
Thanks
Old Apr 17, 2002 | 05:33 PM
fire7882's Avatar
hydro tranny works similar to the way your brakes work. A hydrolic fluid is used to move a piston of some sort, whish in turn moves the clutch fork that engages the clutch. Hope that helps
88 EF Hatch
15
Jan 3, 2009 09:18 AM
88 EF Hatch
Transmission & Drivetrain
Dec 1, 2008 04:14 PM
RHDintegXsi
Aug 24, 2007 08:59 AM
LSV_REX
Jul 5, 2006 05:50 PM
Hayasa15
21
Apr 23, 2002 06:56 PM
