My h22 swap with pics
Old Jun 9, 2006 | 11:51 AM
exratedaccord93's Avatar
Default My h22 swap with pics
Taking out my f-deuce-duece
we were able to get the motor out in less than 4 hours without a lift :D
Me in the motor bay....I usually don't wear cover-alls and a summit racing hat...lol.
Straight gangsta
Thehatchninja humping my new motor :confused:
huge throttle body
And then there was light....
we didn't have any problems mounting it up except the front mount bolt was hitting the header.
I drove it in the garage on Friday at 3:00pm and drove it out on monday at 6:00pm. It started up the first crank and only threw 2 codes (vtec and knock) because I hadn't wired them yet. I'm very disappointed at the power though. I'm thinking it's a timing issue.
Old Jun 9, 2006 | 03:22 PM
teamlegacy's Avatar
Default Re: My h22 swap with pics (exratedaccord93)
you're getting **** power because your ecu is putting itself into limp mode because of the knock sensor error. wire the vtec and knock in and it'll run like a top.
awesome swap, nice job!
edit: i see you're in va. nice to have another performance oriented accord owner around. i used to have an h22 cb7 and thought i was one of the few sometimes, haha!
Old Jun 9, 2006 | 04:16 PM
SuShiBoiiii's Avatar
looks good
Old Jun 9, 2006 | 04:18 PM
93.2's Avatar
Default Re: My h22 swap with pics (SuShiBoiiii)
deuce deuce ftw! glad to see you got a h22...
Old Jun 9, 2006 | 05:52 PM
cambopheonix56's Avatar
Default Re: My h22 swap with pics (g-wagon)
Time to change your sig.
Old Jun 9, 2006 | 09:21 PM
HondaccordH22aJdm's Avatar
Default Re: My h22 swap with pics (cambopheonix56)
BEautiful man.GJ yea knock sensor is maken ur motor not engaging vtec. so whenu wire that up im sure ull feel it.
Old Jun 9, 2006 | 09:39 PM
Default Re: My h22 swap with pics (HondaccordH22aJdm)
Sorry that I wasn't clear on my first post but my ecu threw the codes for vtec and knock, I hadn't wired them up yet. I wired them on thursday and it still doesn't tfeel powerful. The inside of the motor is uber clean but I';; have to run a compression test to see if I've got a blown head gasket. I'll keep you guys posted.
Old Jun 10, 2006 | 02:54 PM
thehatchninja's Avatar
That F22 was hella strong...but the H should be much faster.
post the moped burnout vids.
Modified by thehatchninja at 12:22 AM 6/11/2006
Old Jun 10, 2006 | 02:55 PM
he might have just broken the t-belt....hopefully it was the balance shaft belt.
Old Jun 10, 2006 | 03:20 PM
Default Re: (thehatchninja)
Old Jun 10, 2006 | 04:55 PM
i just talked to him, he's ghetto towing it behind a truck
Old Jun 11, 2006 | 03:59 AM
bigdaddyvtec's Avatar
* B A N N E D *
h22s are slow. shoulda boosted the f- im glad i did, nice swap though....
Old Jun 11, 2006 | 06:35 AM
Default Re: (bigdaddyvtec)
boosted F22 > H22, but his F22 was leaking a lot of oil and had pretty high miles.
Old Jun 11, 2006 | 11:21 AM
devilpuppy's Avatar
how hard was this to do?
did you alreayd have a 5speed f22? so is this as easy as pullin the old out and putting the new h22 in?
or are there more technical things
Old Jun 11, 2006 | 05:19 PM
00HondaAcc22's Avatar
I'm going to swap in an H22 into my 6th gen. My swap is a little more complicated though. Taking an Auto and making in manual. I still need the pedals from an manual Accord, and since I have an LX I need the 4 wheel disc brake assembly from an EX. Anybody know where I can get the pedal assembly, and brake assembly for a 6th Gen 4-door EX...?
Frank
Old Jun 11, 2006 | 08:36 PM
Default Re: (devilpuppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilpuppy &raquo;</TD></TR><TR><TD CLASS="quote">how hard was this to do?
or are there more technical things</TD></TR></TABLE>
it's cake if the motor/tranny are ready to go.....harder if it's an auto. RESEARCH
Old Jun 14, 2006 | 03:28 PM
broken T-belt for sure. AUTO TENSIONERS SUCK
Old Jun 14, 2006 | 04:07 PM
Lewy. Dee Ayy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">broken T-belt for sure. AUTO TENSIONERS SUCK</TD></TR></TABLE>
ouch..
Old Jun 14, 2006 | 05:12 PM
rleonekc's Avatar
great job
Old Jun 14, 2006 | 11:13 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">broken T-belt for sure. AUTO TENSIONERS SUCK</TD></TR></TABLE>let the spending begin!
Old Jun 17, 2006 | 09:46 PM
it happened at idle, and the motor just cut off....probably no bent valves.
manual tensioner conversion + new t.belt should fix it.
Old Jun 17, 2006 | 09:54 PM
londonsupra's Avatar
i highly doubt this.. interferance motor + broken T belt never yelds good results.
it will probally run like poo if it even runs again.
I hope it didnt get ruined though that would upset me so much.
Old Jun 17, 2006 | 10:41 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">it happened at idle, and the motor just cut off....probably no bent valves.
manual tensioner conversion + new t.belt should fix it.</TD></TR></TABLE>
you have no idea. or... as you said so nicely before:
RESEARCH.
or as you have said in another thread:
RESEARCH FOOL.
Old Jun 18, 2006 | 09:00 AM
Default Re: (SuperSlow)
i'm a mechanic fool, I know.
my friend's LS-VTEC with 12.5:1 pistons broke the t-belt at idle and nothing bent.
it's probably fine
Old Jun 18, 2006 | 12:04 PM
what we did for fun....moped burnouts!!!
