HELP ME INSTALL MY JDM INTEGRA BADGE!!!!
Old Jun 9, 2006 | 11:25 AM
hurleyrob's Avatar
Default HELP ME INSTALL MY JDM INTEGRA BADGE!!!!
Ya as my title states....
I am installing my jdm emblems now and I need to know how to take the other ones off. If you have done it tell me how asap!
please and thank you
Old Jun 9, 2006 | 11:32 AM
hurleyrob's Avatar
Default Re: HELP ME INSTALL MY JDM INTEGRA BADGE!!!! (hurleyrob)
bump bump!!!!!!!!! BUMP
i'm working on it now help me out
Old Jun 9, 2006 | 12:29 PM
4U2NV's Avatar
Use dental floss... Run it along behind the emblems and go in a back n forth motion almost like u would use a saw... The dental floss will prolly break a couple of times, but it'll take it off without scratching the paint...
Old Jun 9, 2006 | 12:43 PM
hurleyrob's Avatar
Default Re: HELP ME INSTALL MY JDM INTEGRA BADGE!!!! (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">Use dental floss... Run it along behind the emblems and go in a back n forth motion almost like u would use a saw... The dental floss will prolly break a couple of times, but it'll take it off without scratching the paint...</TD></TR></TABLE>
Thanks buddy! I did just that and it went smooth I took off the acura and rsx symbols so far. The Rsx symbol kinda has a ghost effect still but that will go away.
cheers
Old Jun 9, 2006 | 02:11 PM
BoBoChan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurleyrob &raquo;</TD></TR><TR><TD CLASS="quote">
cheers </TD></TR></TABLE>
maybe not, it might not be the dust/dirt that gives it the RSX outline. It could be the fact that your paint has faded a bit while the paint under the RSX has been shaded.
seenin how you have a black car.. it could be that
Modified by BoBoChan at 8:23 PM 6/9/2006
Old Jun 9, 2006 | 02:52 PM
KOREAN's Avatar
Default Re: HELP ME INSTALL MY JDM INTEGRA BADGE!!!! (BoBoChan)
Use dental floss and if you have a lot of residue, you can use a razor, but be VERY careful. also, if only a very little of that black stuff is left, then just rub it with your finger and it should come off.
btw man, you should have left some tape to show where the ACURA badge was because that's exactly where your integra badge goes, yO!!
Here is mine
Old Jun 10, 2006 | 06:58 AM
MITeggy17's Avatar
Default Re: HELP ME INSTALL MY JDM INTEGRA BADGE!!!! (korean)
Integra Badge Type-S Rear
Type-S Grill
Just incase anyone needed them
Old Jun 10, 2006 | 08:56 AM
hurleyrob's Avatar
Default Re: HELP ME INSTALL MY JDM INTEGRA BADGE!!!! (MITeggy17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korean &raquo;</TD></TR><TR><TD CLASS="quote">Use dental floss and if you have a lot of residue, you can use a razor, but be VERY careful. also, if only a very little of that black stuff is left, then just rub it with your finger and it should come off.
Here is mine
wow looks great man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITeggy17 &raquo;</TD></TR><TR><TD CLASS="quote">Integra Badge Type-S Rear
Type-S Grill
Just incase anyone needed them </TD></TR></TABLE>
That was sooo helpful thanks a lot. I like how it looks now its clean i'll post some pics up soon. I'm debating if i even want to put up my integra badge. right now i have the acura in the middle of my trunk and I left the type S badge.
What are you thoughts? full jdm conversion(integra and type R) ?
Old Jun 10, 2006 | 08:58 AM
hurleyrob's Avatar
Old Jun 10, 2006 | 09:02 AM
hurleyrob's Avatar
I had to rub like a mother ***** to get the glue **** off but it was well worth it now i need to know If i should put this on....
Old Jun 10, 2006 | 10:57 AM
winerep's Avatar
If it is the problem with the glue, you can try using a heat gun or a blow dryer and it will release the glue from the paint. if you use the heat gun don't put it too close to the car either that or you could be bubble the paint if it got too hot.....
Old Jun 10, 2006 | 11:30 AM
MITeggy17's Avatar
Default Re: HELP ME INSTALL MY JDM INTEGRA BADGE!!!! (winerep)
Goo Gone is your friend guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurleyrob &raquo;</TD></TR><TR><TD CLASS="quote">What are you thoughts? full jdm conversion(integra and type R) ? </TD></TR></TABLE>
No, unless you get the k20 motor to back that up. Just just stick with the Integra badge only. Just my .02
Old Jun 10, 2006 | 11:42 AM
25Type-s's Avatar
like he said ^ GOOOOOOOOOO GONE and dental flos
Sinner
Oct 14, 2006 05:05 PM
JjuuN R
Jun 25, 2006 08:58 PM
Jdm_OreO
May 25, 2006 12:36 PM
BUKKAKE-ADAM
May 23, 2005 02:18 PM
VTECPWR
Sep 25, 2002 11:21 AM
