Help Clutch went out
Old Jun 9, 2006 | 10:48 AM
CRX7's Avatar
Default Help Clutch went out
So clutch went on me today, push it in and there is some slight pressure, but no where near where it should be. Will not go into gear while the engine is running.
It's not the clutch cable. I replaced the clutch cable thinking it stretched or snapped, no such luck.
Do I have to pull the transmission? If I do what could it be? The transmission shifts fine when the engine is off.
Old Jun 9, 2006 | 10:53 AM
temp's Avatar
Default Re: Help Clutch went out (CRX7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX7 &raquo;</TD></TR><TR><TD CLASS="quote">So clutch went on me today, push it in and there is some slight pressure, but no where near where it should be. Will not go into gear while the engine is running.
you will need to change the clutch.
http://www.clutchcityonline.com
great deals
Old Jun 9, 2006 | 11:33 AM
si90rex's Avatar
Default Re: Help Clutch went out (temp)
yes u have to pull the tranny its not hard just might take a few days if ur going to do it ur self.
Old Jun 9, 2006 | 12:00 PM
CRX7's Avatar
Default Re: Help Clutch went out (si90rex)
Not the clutch, clutch is new. If the clutch was gone, then it would go into gear but not move anywhere(no clutch engagement)
Old Jun 9, 2006 | 12:05 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX7 &raquo;</TD></TR><TR><TD CLASS="quote">Not the clutch, clutch is new. If the clutch was gone, then it would go into gear but not move anywhere(no clutch engagement)</TD></TR></TABLE>
so wait, your clutch is new, and your clutch cable is new?
check the pedal spring, also make sure you have properly adjusted the tension on the clutch cable.
Old Jun 9, 2006 | 12:32 PM
CRX7's Avatar
Awesome, it was just the tension on the new one which I didn't adjust. Thanks.
MichealSenior
Feb 17, 2009 12:56 AM
88crxdxfastwhip
Aug 2, 2006 07:47 PM
project ak
Aug 1, 2006 10:42 PM
I8ayellowcrayon
Aug 23, 2004 07:18 PM
92TEGGYGSR
Jul 12, 2004 04:56 AM
