gsr cluster
ok guys ive searched and searched and found nothing useful. i have everything else working except the speedo. what ive done was connect the yel/red wire coming from the ecu to the orange wire on the cluster and the vss signal wire(yel/blue). ive connected the vss power to the black/yellow wire,pin location B11 on the cluster and the vss ground to the thermistat housing. so my question is did i mess up somewhere because im not getting nothing from the speedo?
vSS WIRING, piCS.
there are three wires,
1990-95/Accords
A=Blk(ground)
B=Yellow(12Vbattery)
C = Orange (output 5V pulses, to ECU B10, TCU and gauge)
IG = Ignition switch
i have a wiring diagram in which VSS signal goes to B10
Best regards
salman
1990-95/Accords
A=Blk(ground)
Best regards
salman
Lazysk8r2
Feb 19, 2012 06:51 AM
USDMSiR
15
Aug 31, 2006 02:07 PM
