tranny fluid??
Old Jun 8, 2006 | 06:31 PM
chngeovr99's Avatar
Default tranny fluid??
i was wondering what tranny fluid u guys used in ur GSR's or Ls's.... seems like the Acura stuff aint cutting it for my driving.. help me out... plz
Old Jun 8, 2006 | 06:46 PM
GOLDBERG's Avatar
Default Re: tranny fluid?? (chngeovr99)
what do you mean its not cutting it?
Old Jun 8, 2006 | 10:06 PM
volcom40street2's Avatar
check out Pennzoil syncromesh or GM syncromesh.
Its good stuff, search.
Old Jun 8, 2006 | 10:08 PM
Leo C's Avatar
Night Owl
Default Re: tranny fluid?? (volcom40street2)
redline MTF
honda MTF
driving carefully and not grinding gears
Old Jun 9, 2006 | 04:31 AM
Sam92Teg's Avatar
Default Re: tranny fluid?? (shutupnskate)
Honda MTF has been cuttin it for almost 300K miles in my 92 RS.
Old Jun 9, 2006 | 04:34 AM
petergriffen's Avatar
Default Re: tranny fluid?? (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chngeovr99 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering what tranny fluid u guys used in ur GSR's or Ls's.... seems like the Acura stuff aint cutting it for my driving.. help me out... plz</TD></TR></TABLE>
maybe you dont know how to drive
Old Jun 10, 2006 | 06:55 PM
chngeovr99's Avatar
Default Re: tranny fluid?? (petergriffen)
well u could b right... but i dont think so... i race scca and drag race weekly... so i dont think so..
Old Jun 10, 2006 | 07:36 PM
integra3586's Avatar
hmmm, honda mtf has been working out great for me.
how is it not cutting it for you? what is it doing?
Old Jun 10, 2006 | 07:48 PM
akstunt600's Avatar
you can mix but i would DEFFINATELY not reccomend using all gm synchromesh. it is too thin for honda gearboxs
1/2q synchromesh 1.75 10w30 or honda mtf
or try synthetic 10w30
Old Jun 10, 2006 | 07:53 PM
Default Re: (akstunt600)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 &raquo;</TD></TR><TR><TD CLASS="quote">you can mix but i would DEFFINATELY not reccomend using all gm synchromesh. it is too thin for honda gearboxs
or try synthetic 10w30</TD></TR></TABLE>
people run that stuff all the time. its been tried and proven to work
Old Jun 10, 2006 | 08:30 PM
akstunt600's Avatar
yeah but for how long can u run it?????
our synchros NEED thick oil, viscocity rating is TOO low with synchromesh alone. DONT run it by itself. light weight oils in our b/h/d/k transmissions are the number one reason for premature syncho failure!!!!!!
mix it it will help...
the only reason the gm stuff gets rid of grinding is b/c its able to better lubricate while the oil is still cold. once it gets hot the metal softens up and the synchros start to wear out and the grinding will stop b/c the light lube and the soft hot synchro surface
with regular 10w/30 or honda mtf if it will grind while the oil is still cold and will go away as soon as it becomes more fluid and the thicker oil sticks to the synchros much better.
lucas trans fluid would be a good lubricant but it has a high tendeancy to foam up
just stick with what i posted above
10w/30 reg. or syn. and mix it with alil synchromesh
Old Jun 10, 2006 | 08:36 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chngeovr99 &raquo;</TD></TR><TR><TD CLASS="quote">well u could b right... but i dont think so... i race scca and drag race weekly... so i dont think so..</TD></TR></TABLE>
that doesnt mean you know how to..rofl. jp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, honda mtf has been working out great for me.
how is it not cutting it for you? what is it doing?</TD></TR></TABLE>
Old Jun 11, 2006 | 05:06 AM
del sol1658's Avatar
go with redline synthetic MTL - its a 10w30 and formulated for high temp and fast shifting. I have some in my GSR and i just autox occasionally. works good for me
Old Jun 11, 2006 | 09:16 AM
JmurGSR98's Avatar
i use honda mtf and its been working great but i don't race regularly. maybe try using redline.
x_tuh_sy
Dec 10, 2007 03:35 PM
JDM_CRX_PLEASE
Oct 1, 2007 03:16 PM
purple98ek
Jun 6, 2007 06:18 PM
AlekSir
Mar 22, 2005 07:20 AM
CW_97_ITR
Jun 17, 2002 10:48 AM
