LSD? d series/B92+ into 90-91 Bseries?
Old Jun 8, 2006 | 05:07 PM
90_sedan's Avatar
Default LSD? d series/B92+ into 90-91 Bseries?
ok here's the deal.
i have been looking like crazy for a LSD diff for my 91 S1 tranny.
of course i didn't find any...
now i'm looking further. could it be done, to fit a d-series LSD or a B-series 92+. into my 90-91 cable casing?
i know my best option whould be to get a 92-93 tranny. but my tranny is in tip shape. so therfore i don't really want to part out with it.
so any input on this.
Old Jun 8, 2006 | 05:38 PM
CRX Toad's Avatar
Default Re: LSD? d series/B92+ into 90-91 Bseries? (90_sedan)
You couldn't find an LSD? Have you searched these places
http://www.google.com
http://www.ebay.com
http://www.quaifeamerica.com
Anyone that can't find LSD for a Honda isn't trying.
Old Jun 8, 2006 | 06:04 PM
90_sedan's Avatar
Default Re: LSD? d series/B92+ into 90-91 Bseries? (CRX Toad)
ok let me repharse this.
i have been looking for an OEM LSD. i have found plenty of aftermarket LSD, kaaz, Quafie..... and even phantom grips.
if money wasn't an option i whould just go ahead and buy a Kaaz. but the budjet is limited.
i'm asking this question because right now locally there is a D series cable LSD. and a hydro CTR lsd. for sale so. just looking into these option. if they are possible.
Old Jun 8, 2006 | 07:40 PM
89crxhf's Avatar
the only cable b series trannies to have an lsd were the y1 and the ys1 from japan. i have a y1 without a lsd and i can not find an oem for it. there are plenty of aftermarket ones for it. my point is unless you have a ys1 you are pretty much are going to need to go to an aftermarket one IMO.
Old Jun 8, 2006 | 08:12 PM
Crx Jimmy's Avatar
those old oem diffs are junk they are viscous lsd's , either go ats, kaaz, quaife or get a obx off ebay, all of those are way better than the stock even the obx
Old Jun 8, 2006 | 08:33 PM
court's Avatar
25 Year Member
Default Re: LSD? d series/B92+ into 90-91 Bseries? (Crx Jimmy)
y1/s1 diffs can be interchanged. I dont think the y21/ys1, 92+ diffs will work because the ring gear bolt pattern is different
Old Jun 9, 2006 | 06:46 PM
90_sedan's Avatar
seriouslly? OBX LSD bettere than an OEM?
I have heard that OBX is mostlly crappy parts (thats what i have read)
If so an OBX lsd could be one of my options. but will it hold up for a long run? drag launches at 6500rpm, with slicks?
Old Jun 9, 2006 | 07:31 PM
ED9man's Avatar
OBX's suffer from the same problem stock clutch types do, the plates are small and few and have a lot of initial torque to get them to grab hard making them less sensitive and also prone to wear out faster. At least that's what I've hear. For drag racing it might work fine though.
Old Jun 9, 2006 | 08:57 PM
Crx Jimmy's Avatar
Default Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">OBX's suffer from the same problem stock clutch types do, the plates are small and few and have a lot of initial torque to get them to grab hard making them less sensitive and also prone to wear out faster. At least that's what I've hear. For drag racing it might work fine though.</TD></TR></TABLE> ???????
obx's are the same type as a quaife they are gear type and have no plates they are similar to a stock type r diff, which is a good diff but not the older viscous type (y1/s1)
Old Jun 10, 2006 | 08:46 AM
90_sedan's Avatar
ok after seeing this: https://honda-tech.com/zero...age=1 i think i'll pass on the OBX. to bad because the price was in my range .
anyone else any input?
400hpcrx
Aug 18, 2014 04:40 PM
travelor101
Aug 11, 2006 10:27 AM
aXhatch
Feb 20, 2006 12:11 PM
civproject14
18
Feb 8, 2005 12:12 PM
boostylicious
Nov 7, 2004 04:12 PM
