main relay
Old Apr 15, 2002 | 05:34 PM
4doorH22's Avatar
Default main relay
Hey, listen to this. I'm not going to do a stupid search, besides, this place so fricken slow anyways. So I think my main relay is going. I've got all the symptoms. The car has randomly stalled 3 times in the last 7 months, and this evening it refused to start. It would crank and ignite, but then stall as soon as I stopped engaging the starter. I let it sit a few seconds and it started fine. Another guy had this problem with his GSR, but it turned out to be a loose transmission ground cable. All my cables are titte, so I think it's my main relay. Are there any tests I can to do confirm? Is it easy to replace?
THanks.
Old Apr 15, 2002 | 05:36 PM
SOHCArchangel's Avatar
Default Re: main relay (4doorH22)
hrm, i thought your wiring was new from the swap...oO?
Old Apr 15, 2002 | 05:40 PM
4doorH22's Avatar
Default Re: main relay (SOHCArchangel)
PS Anyone got a part number and/or what section of the Helms is this in?
Thanks.
Old Apr 15, 2002 | 05:42 PM
smokin rubber's Avatar
When I had problems with my main relay, it never stalled, it just wouldnt fire up.
Old Apr 15, 2002 | 09:04 PM
89_LXi's Avatar
Default Re: main relay (smokin rubber)
Yea when my main relay went wack it never died, just wouldn't start for several minutes, or would start and sputter for a few sec, then die (usually happened if you popped the clutch and killed it, wouldn't start back up for a couple mins). You should be able to tell by listening for the fuel pump to run when you first turn the key (don't crank), and you can usually hear the relay "click" if it's working properly too. Try this when it won't start and if you don't hear the fuel pump and/or don't hear the click, it's probably main relay time
Old Apr 16, 2002 | 06:22 AM
partsguy's Avatar
New User
Default Re: main relay (89_LXi)
Honda Parts online
Check here Part # should be 39400-sv4-003 or you also can use 39400-sm4-003
Old Apr 16, 2002 | 07:16 AM
Default Re: main relay (partsguy)
oh crap, and i though it was a fluke or a bad fpr
nismogrendel
Apr 24, 2010 01:43 AM
A's 94 GSR
Jun 9, 2008 11:48 AM
95_red_dc
Nov 1, 2007 04:18 PM
91d15bvtec
Jun 27, 2005 06:35 PM
silentblackhat
Jun 10, 2005 07:55 PM
