Torque specs on oil pan bolts..
Old Jun 8, 2006 | 02:46 PM
DCtito's Avatar
Default Torque specs on oil pan bolts..
i had an acura tech tell me 16 inch lbs...then i look in a haynes manual and that shti tells me 104 inch lbs...this is ridiculous
any idea whcih one it's closer too, i'm thinking 16.
it's an b18b1 motor.
Old Jun 8, 2006 | 02:49 PM
devnull's Avatar
Helms Service Manual says 10 ft lbs
104 inch lbs = 8.667 ft lbs
Old Jun 8, 2006 | 02:52 PM
DCtito's Avatar
well i'm curious why the acura tech would tell me such a far off answer...this is my 2nd one because the first one split in half the first time i got on it (******* advanced autoparts ****) this is a honda one but i only torqued the last one down to 50ish inch lbs and it still split like a bitch.
Old Jun 8, 2006 | 03:05 PM
non-VTEC's Avatar
Default Re: (AMGt)
the acura tech told you 16in/lbs because the service manual is wrong on the 10ft/lbs spec. (or atleast i think so and probably all other acura/honda techs)
everytime i try to torque a oil pan to 10ft/lbs like the book says it totally kills the gasket......its impossible that the correct spec is 10ft/lbs....there is no way
i like to use 30-40in/lbs and that seems to work perfectly.
Old Jun 8, 2006 | 04:26 PM
brokeHonda's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the acura tech told you 16in/lbs because the service manual is wrong on the 10ft/lbs spec. (or atleast i think so and probably all other acura/honda techs)
10ft/lbs is wrong! It is 8.7-9.0 ft/lbs.
I am going to guess you are 2 stepping the torque process????
Old Jun 8, 2006 | 06:21 PM
eg6T's Avatar
Default Re: (brokeHonda)
i go around to each bolt hand tight,then go back around and tighten each bolt until i see the gasket start to compress...always works and never had a problem/leak
Old Jun 9, 2006 | 05:19 AM
sepulchral's Avatar
12 Nm
Old Jun 9, 2006 | 05:22 AM
Takumi Fujiwara's Avatar
Default Re: (sepulchral)
I torque them like valve cover nuts... just hand tight with 1/4" ratchet - just until they bottom out.
mengo911
24
Apr 15, 2019 08:44 PM
yellow blur
Dec 22, 2011 05:33 AM
3s0n3
Feb 12, 2006 08:22 AM
minitec
May 6, 2003 04:25 PM
prjctCIVIC
Sep 1, 2001 09:53 PM
