battery relocation: do i still use "stock" gound location?
Old Jun 8, 2006 | 10:52 AM
hatchinprogress's Avatar
Default battery relocation: do i still use "stock" gound location?
ok i've been havin trouble getting my car runnin and i believe it could have somethin to do with my grounds.....the battery was relocated to the rear(crx) by the previous owner, so i wanna re-do it myself (so i know it's done right). well i've been reading up on battery re-locations (i searched) and have heard mixed replies as to where the neg. ground should be? some say the ground wire should be no more than 3ft long....while others say you still need to run the ground all the way back to the original ground spot (because of somethin to do with the starter?)? does anyone have a deffinate answer?? or any kind of input before i go out and buy more (or maybe not enough) wire than i need. also what size do you suggest?? (i was think 2 ga. the whole way)
Old Jun 8, 2006 | 11:09 AM
rsca_crx's Avatar
Default Re: battery relocation: do i still use "stock" gound location? (hatchinprogress)
ground it in the back.
Old Jun 8, 2006 | 11:13 AM
rideblitz's Avatar
Default Re: battery relocation: do i still use "stock" gound location? (rsca_crx)
yep in the back. thats where mine is. i have it grounded where the spare tire used to be. 2ga should be just fine, i think thats what i used too. and 0ga for the positive.
ludesrv's Avatar
No. Too much $$$ in wiring.
I don't know the proper name but, where the spare bolts in, right there, use that little bolt to ground your battery.
Old Jun 8, 2006 | 11:47 AM
dr_latino999's Avatar
Default Re: battery relocation: do i still use "stock" gound location? (ludesrv)
That rusted over for me, so I grounded my battery to my rear shock tower.
Old Jun 8, 2006 | 12:45 PM
ludesrv's Avatar
Default Re: battery relocation: do i still use "stock" gound location? (dr_latino999)
Take a bit of sand paper and expose some metal first.
Old Jun 8, 2006 | 12:47 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">ground it in the back.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Take a bit of sand paper and expose some metal first.</TD></TR></TABLE>
You SHOULD NOT take the ground all the way to the front!
Old Jun 8, 2006 | 02:26 PM
rsca_crx's Avatar
Default Re: battery relocation: do i still use "stock" gound location? (CRX Toad)
you want the ground to be as short as possible. you also want the fuse in the power line to be as close to the battery as possible (within a foot!).
use 2ga cable for everything. i know some people have other opinions, but i've done the math and it's posted around here somewhere, so i'm not going to debate it.
check the old threads if you have any questions on what goes where, or what fuse/breaker to use.
Old Jun 8, 2006 | 05:14 PM
SlobberGoat's Avatar
rsca_crx,
I was planning to run the battery in the back of my CRX and bought about 5 metres of 4 gauge wire. Is this not enough?
(the 4ga is a lot thicker that the standard OEM cables)
can you please elaborate on why you ran 2guage? (i'm guessing you calculated the voltage drop / resistance over a 4 metre span?)
Old Jun 8, 2006 | 05:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Take a bit of sand paper and expose some metal first.</TD></TR></TABLE> That's a good idea, but horrible when your battery won't start because the bare metal has rusted due to the ever present humidity.
Old Jun 8, 2006 | 08:46 PM
rsca_crx's Avatar
Default Re: battery relocation: do i still use "stock" gound location? (SlobberGoat)
here's the faq thread.
https://honda-tech.com/zerothread?id=1131532&page=1
unfortunately my server ate itself and the wiring diagram i drew is gone, but the info is there.
but to answer directly-
yes, it's because i did the math.
yes, you want 2ga. power and ground. 4ga up front after a distribution block to the starter and alternator.
10ft should do a crx for the run up front.
100A breaker or fuse on the power wire within a foot of the battery.
ground in the back and keep it as short as possible.
you need to ground to clean metal. a grounding block looks nice. dielectric grease can help with corrosion.
Prophet1990
Feb 18, 2012 11:21 AM
wicked_b16eg
Jan 6, 2008 11:13 AM
crxh22project
Mar 14, 2005 04:52 PM
basshead
Audio / Security / Video
Jul 5, 2003 11:27 PM
moridin2004
Feb 11, 2003 10:01 PM
