SIZE OF FUEL RAILS TO FIT BIGGER INJECTORS
Old Jun 8, 2006 | 09:28 AM
strongarm1731's Avatar
Default SIZE OF FUEL RAILS TO FIT BIGGER INJECTORS
So i've got a set of 880cc injectors for a skunk2 intake manifold going on a gsr head/block. Im curious if the stock fuel rail will match up OR if i need some sort of aftermarket rail. Also, what kind of injector bottom seals do i need? If i recall, these will be too big to fit in a stock sized seal?
-Don
PS will a fuel rail made for an h22 fit on a gsr, or any B series intake mani?
Old Jun 8, 2006 | 12:05 PM
Default Re: SIZE OF FUEL RAILS TO FIT BIGGER INJECTORS (strongarm1731)
nothin from nobody?
Old Jun 10, 2006 | 08:11 AM
SO CAN PRECISION 880'S FIT IN A STOCK FUEL RAIL?
Old Jun 10, 2006 | 10:16 AM
RedEj8's Avatar
We fit ford 440s in a stock fuel rail, but had to drill the holes out a tad bit bigger.
Old Jun 10, 2006 | 04:23 PM
Mikey3000's Avatar
i'm pretty sure they'll fit in a stock fuel rail. as for the seals, all factory seals fit those injectors.
Old Jun 10, 2006 | 06:43 PM
sc4dr's Avatar
I'm running Precision 880's in my stock fuel rail.
Old Jun 10, 2006 | 07:26 PM
non-VTEC's Avatar
yes you can use the stock fuel rail.
Homesickelian
May 17, 2006 10:02 AM
b20ek
Jun 29, 2003 06:51 PM
MotorMatrix.com
Feb 18, 2003 07:09 PM
dragsol
Jan 7, 2003 07:36 AM
kidkutz
Apr 8, 2002 07:48 PM
