spoon brake pads???need help from itr spoon clappers owners please
Old Jun 8, 2006 | 06:26 AM
19inchbitch's Avatar
Default spoon brake pads???need help from itr spoon clappers owners please
my brake pad dont fit my spoon calipers cause there is a metal pin on the inner pad.did you guys cut the metal sticking on the side or some other mod to make it fit?
Old Jun 8, 2006 | 06:31 AM
743power's Avatar
Default Re: spoon brake pads???need help from itr spoon clappers owners please (19inchbitch)
» Search Results
Your search for spoon pads returned 21 results.
https://honda-tech.com/zerothread?id=1172773
Old Jun 8, 2006 | 06:37 AM
had done many searches but not enough thanks but what about the little dot on the pad where on the other side there is the metal sticking do i grind it to?
Old Jun 8, 2006 | 06:38 AM
pitargue's Avatar
Take off the metal clips and grind off the nipple that remains...
Old Jun 8, 2006 | 07:00 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: (19inchbitch)
Just drill thru the rivet that holds the clip in place. The clip will fall right out.
Old Jun 8, 2006 | 07:17 AM
AssPenny's Avatar
Default Re: (Wai)
or
Just smooth down all the bumps and you are ready to rock
RagingAngel's Avatar
Default Re: (Wai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">Just drill thru the rivet that holds the clip in place. The clip will fall right out.</TD></TR></TABLE>
Engineeers are always so proper....
I just took some pliers, gritted my teeth, swore at it and tore it off.
Old Jun 8, 2006 | 07:31 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
I just took some pliers, gritted my teeth, swore at it and tore it off. </TD></TR></TABLE>
lol, x2
racin jasin R
Feb 17, 2011 06:52 PM
Quickridez_3
Apr 4, 2008 04:29 PM
cume
Jun 15, 2007 09:51 PM
Jin Yamato
17
Jan 7, 2003 02:10 PM
